Been defected. went over the pits.
didnt really expect to pass first time
R34 gtt. turbo manual.
I have a rear lock bar installed.
howmuch is the whole standard HICAS system worth ? hard to put back in ? where can I get it, hard to find.
front castor rods need to be engineered or fitted with stock parts. same deal..
cheers.
https://www.sau.com.au/forums/topic/228273-hicas-defected-lock-bar-etc/
You cant just remove the lock bar.
To fit the lock bar you have to remove the electric motor that hooks up to the standard toe arms.. All you will need is this electric hicas motor, its not hard to put in. A suspension shop should be able to do it in under an hour easy.
