Guest nismogtsx
First Bike = 140kph (ZZR 250 @ 10000rpm - wasent going it too much)
Second Bike = 280kph (R9 @ 18000rpm)
Third Bike = almost 300
First Car = 150kph (torana @ 4700rpm LOL)
Second Car = 240kph+ (Pintara @ 8000rpm LOL)
Third Car = 180 (180SX @ 6400rpm)
Forth Car = 195kph (Magna @ 6000rpm)
Fifth Car = 240kph (Skyline @ 6100rpm)
All on dads property.... Really.... HAHAHAHA
Its also true the Pintara got 240+kph... It took me almost 5 minutes to achieve that speed and i had a mate on a bike beside me mesuring the speed. I broke the gaudge after that one, i would not go over 90kph again... LOL
Also the third bike mas a mates drag bike not a road bike, trust me the R9 at 280 was #!$@ un controlable i thought i saw my life flash before my eyes and have never and will never go that speed again on one wheel...LOL
https://www.sau.com.au/forums/topic/2283-speed/page/5/#findComment-60732
  • Replies 103
http://www.exvitermini.com/movies/wngn0.mpg
This is probably the best description of speed I have seen!!! R33 doing 300+ km/h over Tokyo Bay bridge!!!! This and other movies can be found on Mario's site http://www.exvitermini.com/ in the movies section / various (most of you probably knew this!!)
Mario owns the fastest GTR in OZ!!!(probably knew that too!!!)
I too have hit the 180kph speed limiter!! have also done 278kph on my R6 motorbike(now destroyed due to my heavy right wrist!!) on a private road!!(my driveway ha ha :( )
MEGA
https://www.sau.com.au/forums/topic/2283-speed/page/5/#findComment-60749
Mostly on topic.
I've had my apparently stock R33 to 210(ish) at Eastern Creek, but no sign of the speed limiter cutting in. Are the speedos that innaccurate? Could the limit have been removed (if so, how could I tell)? For those who've hit it, a description of the effect would be appreciated - the redline 7,200 in fourth is approx 190, are you sure that's not what stopped you?
https://www.sau.com.au/forums/topic/2283-speed/page/5/#findComment-60790
5500 rpm in 5th in a rb gemini. works out to be about 220 on gearing
how and when. basically comming back from the snow floored it from cambera and hit the speed on the big hill half way home.
not the fatsest but had 4 people in the car and ski gear and on four retreads (oh the stupid **** you do when you r young).. but *** me what a rush
pete
https://www.sau.com.au/forums/topic/2283-speed/page/5/#findComment-61031
Originally posted by Duncan
Mostly on topic.
What rpm Duncan? I think it's about 40 kmh/1000rpm in 5th.
210 kmh=5250 rpm
https://www.sau.com.au/forums/topic/2283-speed/page/5/#findComment-61039
No idea on what RPM in 5th - I'll take a quick peak next time.
But does anyone know the numbers for 4th? It was indicating approx 190 at 7,200 in 4th.
Or more to the point, how can the speedo be tested for accuracy?
https://www.sau.com.au/forums/topic/2283-speed/page/5/#findComment-61171
Any GPS will be more accurate than a speedo. Handheld, dashmounted doesn't matter. Dash speed in your boat is probably taken from a revolving sensor in the water. Susceptible to weed etc, same with the Depth sounder usually. Also the GPS gives ground speed only, where the others are speed through the water with no correction for current.
https://www.sau.com.au/forums/topic/2283-speed/page/5/#findComment-61219
  • 5 months later...
On F1 going to newcastle from sydney arvo hit the speed limiter it looked as if it went 20km pass the 180km on the speedo... so 200km/h? if you measure the spacing between the speeds..
=) well stayed their for half a minute before the orange engine light turned on.. wondered what that meant?..
Stock R33gts25t series II
https://www.sau.com.au/forums/topic/2283-speed/page/5/#findComment-217478
Guest LoudBlueBMW
200km/h in 4th gear at 6500rpm redline (car is only a 4 speed) With the work done to it it took no time to get there and would easily use 5th to its advantage. With one point left I think a 4 speed gets me into enough trouble..... never mind the noise the car makes over 4k rpm....
https://www.sau.com.au/forums/topic/2283-speed/page/5/#findComment-219237
Ford Proving Ground 2000 Grand Prix
Rally
1997 R33 GTR
You start at the start of the banking
and your time is taken half way down the first straight bit flying eight mile plus
police radar
offical time 258kph
willow bank Indy Rally 2001 drove in off the street removed spare and luggage
first run 11.701
but I'm getting a bit old and slow these days!!!
https://www.sau.com.au/forums/topic/2283-speed/page/5/#findComment-240633
Originally posted by red900ss
With a GPS ;)
lol, a thread back from the dead!
And your words were prophetic Dino, I've now got a road angel in the car which includes GPS speedo....so I'll be able to answer my own question from EC on Thur
https://www.sau.com.au/forums/topic/2283-speed/page/5/#findComment-240678
with me behind the wheel
190km/h in a 98 vs stock commo (mum's car :D)
Got the 88 vl, also stock to 160 but it didn't seem to like it much
mate behind the wheel with 5 in the car, 96 (i think) subaru liberty sedan to 180km/h
all this on the same stretch of uhh private road *cough* vs felt like it coulda gone alot further but the road has a hill that cops tend to sit on on the other side so you wanna be doin 120 before you hit the top of it.
when I get my line i know the speedlimiter will be one of the first things to go :)
https://www.sau.com.au/forums/topic/2283-speed/page/5/#findComment-241454
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
