all on private roads of course.
lexus ls430 - 240km (hit the speed limiter)
lexus is300 - 200km (hit redline in last gear :-()
nissan silvia s15 - 210km (with not much legs left)
proton satria gti - 205km (redline in last gear)
and my proudest moment
toyota starlet 1.3l - 190ishkm/h (down a big big hill right off the speedo, that was damn scary, i had speed wobbles)
https://www.sau.com.au/forums/topic/2283-speed/page/2/#findComment-42072
  • Replies 103
Originally posted by PranK
NismoGirl, did you fix the problem with the car after changing the piping back to norm?
Yeah.. we just put the old pipe back on. It ran like sh*t for about 30 minutes after that but we took it for a squirt around the local streets..
I am taking the car down to the mechanics tomorrow to get it taken off properly. And to get numerous other things fixed.
So if its not running right.. its then not my fault :)
https://www.sau.com.au/forums/topic/2283-speed/page/2/#findComment-42074
210km/h indicated in a soft top capri turbo BLOODY noisy as one would imagine due to the wind noise, mirrors vibrating etc but wasn't fully wound out think was doing 6000rpm rev limiter @6800 o and obviously this was on a private racetrack cause we all know that it is illegal to do that on the main roads! mates zcar has hit 246km/h not fully wound out due to having to get on the brakes when he caught up to a truck on a hill!
https://www.sau.com.au/forums/topic/2283-speed/page/2/#findComment-42118
sealed off section of road, in the gtr 5th gear roun 8000rpm needle was facing in six o'clock position i cant be sure what that would actually be but round 245 or so! Everything after that felt so damn slow:uh-huh:
https://www.sau.com.au/forums/topic/2283-speed/page/2/#findComment-42245
210+ in a suzuki swift GTi, was tracking all over the road pretty badly. I guess the guy who owned it before me and dropped the height by cutting the springs wasn't going for the whole 200+ idea. Dam Qik can confirm this, as he overtook me, I think he was doing around 250 or so. Anyway looked hell cool as he went past
I got my skyline up to 190 45mins after picking it up. Can't wait to cut that pesky little wire, or at least put in a toggle switch.
I don't know about you other guys, but **** "private" roads this was on a public road at 3am in the morning. Good old Bruce Highway.
Haven't done a quarter mile yet, got a few bugs to iron out before I give it a eal good hammering
Tim
https://www.sau.com.au/forums/topic/2283-speed/page/2/#findComment-42468
Official top speed is 260km/h the needle just touched the pin at 0 and I worked out that this is about 260km/h.
Fastest 1/4 13.7
Closest miss....Slowing from 220km/h on a "Private" Country road and my rear tyre blew at 180km/h. Didn't notice till much slower and I tried to take a medium corner and the back end felt like jelly. It was at this point that I found that I could get a jack under my car cause it was too low.
Later at the tyre shop the guy looked at it and asked how fast I was going....I just smiled and he informed me that the crap tyres (his words) were only rated to 160km/h. I nearly died.
https://www.sau.com.au/forums/topic/2283-speed/page/2/#findComment-42671
TYRE SPEED SYMBOL TYRE SPEED RATING
S 180 km/h or 112 mph
T 190 km/h or 118 mph
U 200 km/h or 125 mph
H 210 km/h or 130 mph
V 240 km/h or 149 mph
W (ZR) 270 km/h or 168 mph
Y (ZR) 300 km/h or 186 mph
ZR Above 240 km/h or 149 mph
Note this is off Kumo, but is pretty much standard across the board
*whoops, same info as that link, sorry*
https://www.sau.com.au/forums/topic/2283-speed/page/2/#findComment-42692
I have done 210 (half my heart rate) in my falcon with the first part down a hill to get the speed up, They feel like boats at 100. Not much fun at 210. They also dont brake too good, a whole lotta brake fade from 160+.
Also done 200 in the same car up the Hume on a lazy sunday.
https://www.sau.com.au/forums/topic/2283-speed/page/2/#findComment-42729
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that green thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
