  • Replies 103
polishstorm, you are one lucky guy :uh-huh:
the magistrate must have been in a good mood :D
i can't believe you went that fast on the Parkway in the first place...that's scary stuff...with all those concrete walls in the middle...
the times I've done it have been out on a highway, where there's big wide roads and long straights you can see the end of.
https://www.sau.com.au/forums/topic/2283-speed/page/4/#findComment-43547
Originally posted by Piggaz
coudlnt be that hard... 'can we see the car u were using'
lol
L.A.Z.Y.
this was 2 years ago and unfortunately some low life bastard stole the car but i still have all the engineer papers and photos of it but i dont have a scannes to post them up.
https://www.sau.com.au/forums/topic/2283-speed/page/4/#findComment-43641
Fastest was 230 in an S14 (very floaty, don't try it), but as for cut off - I hit 190klm on the straight at EC, and I originally thought I was hitting speed cut out, turned out to be the rev limit in fourth! Still not sure if/where the rev limit is (since 5th is no faster :D )
Keep in mind that speedos are up to 10% optimistic - so the 180 limit may still be there while the speedo reads 198!
https://www.sau.com.au/forums/topic/2283-speed/page/4/#findComment-44910
Guest SVD001
to PJKJ..Yep I'm in ipy all right..:P Not a good thing but it'll do for now. Haven't been on any cruizes as yet. Only went to that Drift day out at Mt Cotton the other week. seeing as tho you live in Ipswich,, Have you seen that gorgeous silver R31 that's always parked outside of Kenard's Hire heading out of town??? It's got SKY89 or 89SKY plates on it. I'm keen to go in there one day and ask who owns it... I'd like to go on a mountain drive at some stage. Surely others would be up to it......
https://www.sau.com.au/forums/topic/2283-speed/page/4/#findComment-45238
280 km/hr in a HJ Holden Ute! (Years ago)
Had 502ci Chev(8.2L), 5 spd Tremec, & 2.5:1 nine inch diff!
Got busted on freeway doing 160 at exactly 2000rpm in 5th -
so we worked out at 3500 it was doing roughly 280.
Crazy thing is it would of pulled to 4000 rpm in 5th, but I doubt
it would of stayed on the road at over 300 kays!!!
10.1 @ 133 mph in a HX Holden Ute! (also years ago)
Had 350 chev, powerglide,5.11 diff, & 32x14 slicks.Ran methanol.
Dinosaurs all gone now.(well almost-have commodore ute)
R34 GTR - 12.5 @ 114mph. Std exept for Power FC & Nismo Exhaust. Need to get 320 Km speedo 'cause it maxs out the std 180 km speedo well before 7000 rpm in 4th & I've had it doing
over that in 5th. Haven't really stretched it's legs in 6th yet!
*have now - does 285km & 12.1 @ 115mph*
R33 GTR - 10.7 @ 135mph (So far) at Drag Combat.
Looking forward to breaking past the 140 mph barrier.
It was doing around 8000 rpm in 4th over the line when it did
135mph (216 km/hr) so imagine 9000 rpm in 5th & 6th?
Has trust 6 speed. Will have to finalise last will & testament before attempting this! ( In Northern Territory of course)
*now 9.66 @ 148mph with Holinger 6 speed*
*now 9.50 @ 153mph but didnt back off till 265km according to datalogging - pity the track isn't longer.*
https://www.sau.com.au/forums/topic/2283-speed/page/4/#findComment-45749
  • 3 weeks later...
About 250, not absolutely sure it is hell scary at that speed. My mate in the back seat says it was 245-250. Ran out of gearing to go faster, engined pulled fairly happily all the out to this speed. This was driving between hometown and industrial town with excelent highways. That time was enough for me, won't do that again soon.
This is usually 4 hour drive. We cruised nearly all the way at about 180, anything above that my external wastgate was activated and was noisy and gave me the ****s. At one satge we had to stop (potty break), tried to catch up to cars that are allready going 150, not easy. Took nearly 15 minotes of 200 plus driving.
This road is well known for no cops, everyone speeds along it.
https://www.sau.com.au/forums/topic/2283-speed/page/4/#findComment-60725
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
