Car Finially On The Road Again
Guest INASNT
After over a month of my car sitting at ice with problem after problem i finially get to drive it again, YAY!!!
The 550cc sard injectors, 044 pump, z32 afm, Power Fc, Greedy Profec B Spec 2, 9 Puck Cermaic clutch with 1200kg pressure plate, Lightened 4.5kg Chromemolly flywheel, Pineapples and Adj HKS Cam gear are all in and had a light tune with the Power Fc and got around 185rwkw@12psi .
The new custom made 3037S with 45mm external wastegate and custom high mount exhaust manifold are going on in the next few weeks. Same guy making my turbo as who made leewahs.
First with the exhaust cam gear set at -2.7 degrees, the profec b spec 2 setup properly with the pfc tune and lightened flywheel I am getting 12psi by 2000rpm!!!. Secondly the new clutch is farking heavy as and the friction point is mm off the the floor which means i have to rev to about 1500rpm before i can take off or else it stalls, so if i take off at 1500rpm, 500rpm later i have the full 12psi boost kick in. Not fun at all in the wet as I come off the clutch at the lights with the wheels already spinning before i even start to move. Should be more drivable when the new turbo setup goes on.
I recommend the lighhened flywheel to anyone as even tho i got the same peak rwkw as before with the ligtened flywheel and pfc tune it accelerates just so much faster and i got soooo much more midrange power now than before.
Will keep updated when new turbo setup finially goes on.
https://www.sau.com.au/forums/topic/22833-car-finially-on-the-road-again/
  • Replies 42
nice..nice! that 3037 might just stretch those internals a bit too much though I have a feeling..
u should take it to Calder before they put the new turbs on...
Pity I have given up the mod-chase with mine anymore... my next project I have in mind however should give u a nice little run in those tropics :) I'll only need about 230-240rwkw to match you too..
Clutch will wear in and be nice .. at first they're a bitch... the last owner of mine changed it recently before he sold it. For the first couple of months was a pig to start, esp in the wet! it was either stall or spin stupidly..but it sorted itself out.
Guest INASNT
meggala
I been driving around automatic hire cars the last few month so any clutch at the moment would be hard i guess.
The 3037 i am getting will be
Comp
56 trim/57.0 Inducer / 76.2 Major. Hosing - 0.6 A/R
Turbine
Wheel 84 Trim - 60 major /55 Exducer
Housing 0.87 A/R
Robos
What power did your car make?
Gordo
I hope it looses a bit of its bite. And yes we should try go to Calder again but i am flying back to cairns on wednesday morning and returning friday morning. Fark i been over in cairns more in the last 3 months than been in melbourne, and the roads up ther west of cairns about 200km are just dead straight for about 5 km's in stages, its so tempting to just go full throttle.
As for the internals i have already scoped prices on weisco forged piston/rings and rods, mild ported head work, 1.6mm HKS head gasket and 260 duration intake/ext Tomei cams. They cost a bit but not 2 unreasonable.
Grim
U cant change the intake side with cam gears as then u will loose the nivac. I should be able to retard the timing to about -4 once the new turbo is setup and a bit more time is spent tuning the pfc. The exhaust cam gear, profec b and the pfc tune helped i recon the boost to come on so low plus its a series 2 so it uses the so called plastic comp wheel.
Guest INASNT
Originally posted by Grim
Denham....are you working your car up for the track or the drag strip? How many times have you had it on the track or run it at the strip?
Most prob drag strip, as not much track action goes on here in mel
Pic of the casing, u think there will be much lag?? :)
Guest Robo's
Originally posted by INASNT
meggala
Robos
We got 178rwkw peak, didnt want anymore plus the stock cooler was heating up, last run was 172rwkw with a little less boost. This was during SAFC tuning.
Feels so much better
Hey Denham,
Seems like the guy working on your turbo does look like the same guy who did mine ;) Good work on it all mate. Your car almost became part of the furniture mate. Pity you didn't have a huge spoiler, I wanted somewhere to put my Maccas the other day :D
I got Nittos if you wanna buy some.
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
