hey every one i was just wondering has any one experienced this problem. i got an r32 and it seems to idle high. it idle around 1700 rpm was just wondering would that be the idle air control motor faulty because i am aware of the idle set screw on the housing of the iac however ive screwed it down and the best idle i can get is around 1700rpm. with the idle air control disconnected i can get a more appropriate idle going however it wants to stall on me at times. was just wondering has anyone had a simular problem and found it to be the iac or is there a learn function on the skyline to setup the idle?
i read in a recent thread on here that a dodgey tps will make the ecu default to a 1500rev idle?
are you sure you have wound the adjusting screw far enough in? mine was siezed & it wasnt till i undid it all the way out, sprayed wd40 on it that i could actually wind it in far enough to get a 600rev idle
mines defenetly not siezed. i removed the iac before it seemed really blocked up with carbon so yeh. i cleaned it out with throttle body cleaner and fitted made no difference. a dodgy tps would give you flat spots wouldnt it? i dont seem to have that problem but its something worth lookign at
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
