Incase there are any engineers or experienced modifiers here.
I own a pretty stock R32 GTST Type M. FMIC, Fuel pump, exhaust, filter. I have a Garret 500HP turbo waiting at home, a power FC & injectors to be purchased soon. when I put this all on and get it tuned, then question is. CAN I GET IT ENGINEERED?
any help would be great guys. I am in the sydney area. I just want to be able to drive it without hassles if I get pulled over. or be able to fight any defects or fines if it happens. its an everyday driver. :)
https://www.sau.com.au/forums/topic/22836-help-engineer-questions/
I think the simple answer is no. Going from the WA laws, which I know may be different, any mods which have an impact on the engines function would require it to pass not only structural test, but more importantly EPA tests.
The EPA test here involves a rolling test on a special dyno, to make sure the emmisions still meet with the orignal car specs. It costs about $2000 here at the moment for this test:(
Contact an engineering signatory and ask them. They will be able to tell you what can and can't be done legally. VSI 02 contains the list of signatories.
http://www.rta.nsw.gov.au/registration/dow...cinfor_dl1.html
Also an excerpt from VSI 06
Engine modification
Original engine modified
Modifications to the original engine are permitted provided the following conditions are met:
*normal engine reconditioning within manufacturer’s limits is permitted; .
*modifications must not affect compliance with any emission or noise related ADRs;
*all emission control equipment must be retained and functional;
*if the modifications result in a substantial increase in power, then the adequacy of other components to carry the increased power (brake performance, vehicle controllability and suspension systems etc.) as well as the vehicle’s continued compliance with the applicable ADRs must be considered.
Please post whatever you find out.
Yeah, we spoke to the head of the pit inspections of here, and he basically said, if we can't see it then we aren't going to worry about it:D Just don't put huge lumpy cams in, cause that's kinda obvious:D I have an aftermarket ECU, but it's hidden behind the kick panel.
No. You can't.
Theres no way you can actually get a car engineered with a programmable ECU, you can get it passed via the test, but still what stops you changing the settings after you have passed.
Its a risk if you run a aftermarket ECU/Boost controller/Aftermarket turbos etc etc etc......
I dont think that there is anything stopping you from getting programmable management engineered! My mate had his sprinter engineered running a CA18DET with microtech computer!! just had to have emissions test etc before it would be passed!! Even with an engineers cert nsw police and rta reserve the right to have it tested again at anystage!!
  • 4 years later...
No. You can't.
Incorrect.
If the ECU is password protected from any change in settings (settings that only get programmed by an authorised tuner) then it can be engineered.
A good example of this is Haltech.
Incorrect.
And Power FC
Cheers
Gary
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
    • Righto,  enough of ADHD Anonymous! 🤣🤣 Rear end is completely stripped out apart from coil overs that will take 5 minutes.  Fingers crossed it doesn't look like that for too long!   Cleaning up some bits as I go so they can go straight back on. It amazes me how good stuff looks just with a good hard scrub! That will be it for a couple of weeks. I've got ot a bit of surgery Friday that will put me out of action for a few weeks. Hopefully the motivation is still there when I'm ready to get back into it!
    • The povo spec CA18S one, yeah. All turbos had 16x6.5 5 stud and 4pot brakes.
