uhhh its more likelythe owners got 3.9 gears in a commdore then it is hes got a supra making 560rwkw at ~1bar....
you can get any gears in any car, its not a big deal, i wouldnt base your answer off that
Considering it's revving to 7200RPM by those graphs...
I'm going with a worked LS2 due to the revs + torque
maybe you will all get a surprise, it does say trent LTD at the top, maybe he has put some work into his tank...
i wish, my shitter tank makes 180rwkw :( with a nice 395,596km's on the clock..... it turns fuel into noise and pollution... and of cause its a clevo...HEAT.
i must admit i now need to claim back top dog on my dyno so ive fast tracked the tank....ditched the blown clevo idea in favour of a blown windsor stroker (427) possibly twin 1.06 a/r GT35 or 10cm T67's.... parts for windsor are far easier to track down....
Here is the car in question 408cube, peter starr supercharged maloo ute..... sweet car that honestley is streetable..... mini tubbbed with custom 11" HSV wheels... and full exhaust.
will fix pics 2moro.
Has it got a madmax style supercharger clutch??? haha
Would love to drive one of these new wave of forced fed falcodores, they are real torque monsters.
and yogibear pretty sure digital cameras werent around in the 60's, and the cameras that they did have took rather good quality pictures....
Nice power.
wow 400 cubes that punches out 50 or so NM less then my 3 litre on 1.7 bar :D
.9 bar to get that kinda force is insane.... is the wick going to be turned up at all?
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
