any news 'boostdR' about your choice with turbo setup? how did u go with the gtrs v's 618z?
i am looking at the same thing & possibly building up an rb30 with 618z's (my current gtss setup will be too small for an rb30 if i take this path)
  • 1 month later...
  • Replies 107
Posted Images
  • 6 months later...
im not sure where matt is up to but ive got my setup running.
my 'forklift' rb30 (tongue in cheek dirtgarage lol) with garrett -10's made 270.9awkw @ 6500rpm on 10psi, rich run-in tune.
final tune is booked for next week :) very happy with results thus far
i posted a thread here with dyno graph if u want more info: http://www.skylinesaustralia.com/forums/Pr...la-t277399.html
  • 1 year later...
Hi all,
I ended up with a 89mm sleeved bore rb263# ?? HKS GTRS turbo's, E85 and 8.7 to 8.8:1 Comp for E85. I have had it on the Dyno for a initial tune. Maxed the fuel pump out @ 534kw and 20psi. I have a new fuel pump now and will install and get it happening.
Will be playing with the ingnition trasition onto boost and the cam gears for some extra response. I am using Stainless Mani's but may see if the 6boost ones fit without having to move all my lines.
Matt
Before and after. Similar response with more power
For those wanting to know if the HKS version of turbo is better. I can say they still surge slightly when loading up on boost in a high gear/low rpm...sound like a Cho cho train. I have no BOV's. Installing the std BOV's would prob fix most part throttle surge...but it's very minor and doesn't bother me.
Edited by BoostdR
Me personally, I'd go for HKS GT-RS twins interestingly. I'm not arguing with what your tuner says - but if I had not heard that and for some strange reason I wanted to go for twins at that power level, HKS GT-RS would be floating around the top of my list. Going for under 272deg duration is probably not something I'd do when going for turbos that size/power that high however.
The CAMS I ended up using are much smaller than 272 with just under 10mm. They work extremmely well. The Prelude was that we actually ordered a set of JUN 272's for a customers track GTR with -10's but by mistake got the lower duration and figured we will give them a go...results were very impressive and suprising to say the least.
Hi all,
Matt
534kw YIKES!
u make me want to switch to E85 sooner rather than later! with that fuel u should be able to run 30psi without a problem.
is this power reading rwkw, awkw or engine dyno?
amazing power from the good old low mount setup, congrats :P:):P
that 380kw is a lie, check out the intake temps of 63degrees,
lol, agreed. Not sure what the correction would be. I have other graphs for 372 @ IT of ~21degree's
good spot
I more put it up for a Curve comparsion
534kw YIKES!
amazing power from the good old low mount setup, congrats :P:P;)
It's at the Fly Marko. Was 457kw at the wheels.
Fuel setup currently is a GTR pump and single 044. I have another 044 to go in. Injectors(1000cc) are pretty much out of flow already even with my high rail pressure.
haha, atleast u admit it lol.
when are you taking it to test it at eastern creek
I don't live in Syd anymore. I'm in Adelaide. Will be at Mallala this weekend.
Will be Pit Crewing at Eastern Creek on the 3-5th of Sep. Might bring it up to WSID on the truck.....May need a couple of spare gearboxes...
When will be you be at Mallala on the weekend, weather permitting I guess? Would not mind coming to have a look if you wouldnt mind...
that figure of 457awkw is aligned with what my tuner advised i could achieve if i switched to e85.
what exhuast diameter are u running?
Will be there on Sat. All day
Come say Hi.
Matt
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
