are u looking at running the baffle mod in the factory pipe as well?
u getting any shuffle/surge on light throttle under low revs?
best way test it, 50kmh in 4th then flatten the throttle
I do get the choo choo. Not interested in the baffle plate. My guess is it fixes the choo but would increase restriction on the front turbo. Best go for a smooth transition Y pipe.
  • Replies 107
Posted Images
My Trust pipe kit is a long and smooth transission... good angles too. Worth every cent in my opinion.
J.
around 1200 7 years ago.
they're on ebay in the US for 900 new.
I was going to make my own pipe work, but for the effort, materials and buggering around.... it's worth 1100 bucks! not to mention it performs as well as anything I could have made and it looks alot neater too.
Well designed and well made. From memory, it only took 3 or 4 hrs to fitt.
Cheers
Justin
Cheers
Justin
can u see your low mount turbos a lot easier with the pipe kit? it definitely looks cleaner
Yeah, I guess you can see the turbos a little better... It's still pretty crowded in there though.
I realy like the look of neat trust/hks low mount pipe kits.
  • 9 months later...
Looks like fun at Mallala. I was going to say you seemed to have some difficulty easing it onto power out of the corners till I saw that you had 4wd issues.
Also saw from your walk around video that you have the same massive shuffling issue that I had before switching to a d-jetro. Give it a decent free rev and one turbo will spool up more than the other, which directly affects your Maf sensor voltages. If you enable some watches on your MAF sensors with a datalogit, you will see a 1.5-2v variation between the MAF sensor voltages. So the ecu over fuels the hell out of it because it thinks its under load when its actually idling.
Given the opportunity to try something else to tune around it and retain MAF sensor smooth tuning capability, I'd want to try a single MAF sensor and put it in the cold side of the intercooler before the plenum.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
