in the morning when i turn my car on..(infact anywhere where the car has been sitting for more then 30 mins off) theres a ticking comming from my bay, but only at around 2500>3000, not when its idleing, i pop the hood to find its comming from the front of the block, on the right side (turbo side) of the rocket cover when i rev it.. after driving for about 10 mins it goes away, what the hell is this..is it serious? thanks for reading :) car: R32 GTST 1992
https://www.sau.com.au/forums/topic/228428-weird-stupid-noise-heeeeeelp/
Skylines and engine bay noises, do search...
When were your timing belt idler and tensioner pulley's last replaced? I've had this issue, I reckon i was a few weeks away from a seized bearing, overheated and snapped timing belt :)
Sure its not your injectors? If you race the motor, does the noise disappear on the decel? What oil and when was it changed last?
Regardless, poke about the engine bay with a long screwdriver on your ear.
i change oil every 3000k's, it started actually after switching from valvoline to caltex synthetic oil....timing belt changed at 93 000ks, its done 132 000 now..
lol sorry i tryed search b ut came up with similer issues but not the same, it ticks only wen i accelerate,, then it goes away completely... its perfect at idle..
Edited by SXCR32
Check your starter. There is a thing called "the clicker" it is known as this because, well, it clicks. When you start the car it should click for about... oh, I would say 10 minutes max when running. Normally it is out of 2nd gear as well because the engine is warmer. Then the clicking is better on warm days etc. That could mean a bad starter. That is why they make it like that. X__X;;
Happend to me and I ignored it, then I got stuck in the middle of nowhere.
Just something to ponder mate.
If this IS the case, don't replace it. It can be repaired for like 25$ easy. Take it to a shop is all.
Edited by AKW
since it was after a oil change i would also have to go with a lifter. get this a bit at work. when you change the oil and put a new filter on you induce a fair bit of air into your engines oil gallerys which can enter a lifter pretty easily, usually it will go away after a bit of driving. if not, lifter could possibly be on its way out...
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used thisĀ https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/ Ā  shut my nismo 1.5 pro up by heapsā€¦. Not silent though. Gives the car character and personality. It ainā€™t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a considerationĀ  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
Ɨ
Ɨ
