Simonster Posted July 16, 2008 Share Posted July 16, 2008 Posting here for a friend, here's the specs 25 head, light port, HKS 265 9mm both inlet /ex, Jun valve springs, JE flat tops pistons, compression 8.3:1 Bottom end, RB30, ACL bearings, RB30 rods shot-peened linished balanced, crank drilled grub screwed, etc Rigoli plenum, 1000cc Rochestor injectors, 044 pump, sard reg, 6 into 1 ex manifold , external gate turbo smart, GT3040 turbo, 17psi spring SM4, CDI, NGK8's, tuned my Matt Spry. Car has been well and truly run in. The car with standard cams made 330 rwhp at 17psi , now with 265 cams, making 325 rwhp?? We are all at a bit of a loss at the low numbers, we expected decent numbers from this set-up. Any suggestions are welcome. Thanks Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/ Share on other sites More sharing options...
R31Nismoid Posted July 16, 2008 Share Posted July 16, 2008 Why is the compression low? hmm... 17psi, should be seeing a solid 270-280rwkw being i made that on a factoy head, cams, plenum etc etc... and that was 3 years ago on a 2.5ltr, so on a 3ltr, 17psi you'd almost be expecting a round 300. What does the tuner have to say about it all? What happens when you put more boost in? some fairly serious gear there considering its a small turbo Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/#findComment-4019154 Share on other sites More sharing options...
paulr33 Posted July 17, 2008 Share Posted July 17, 2008 id be looking at the dyno graph, plot power and boost it might give away an inlet restriction, or exhaust restriction particulary the manifold might be making it choke, so no power gains regardless of how much boost you dial in Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/#findComment-4019642 Share on other sites More sharing options...
Simonster Posted July 17, 2008 Author Share Posted July 17, 2008 The turbo is the original 3040 from many years ago, when it came out it was supposed to be rated at 600hp, so there shouldn't be a problem there. I have another 35/40 that we can fit if need be but we don't think its the turbo. The Matt doesn't know why the power is no there. My thoughts are ( i wasn't there when it was tuned) 1. the car isn't holding the required timing when under load...yes i know it an SM4 it has all the gear to make all the numbers- its just not. (i have an SM2- so there is no hatred of Autronic) 2. compression is down on one of the cylinders- that said it is yet to have a compression check to see if that's the case The car owner thinks its not really making 17psi. If it was making those numbers on 13-14psi there'd be no real problem, so we are fitting other boost gauges to triple check this. The cams were slowly being dialed in and were producing gains in the right direction, just not the numbers Yes its got some serious gear, the compression is "low" as he is fine running big boost and lower static compression. Keep in mind it's only very recently (last 2 year or so ) that its become the norm to have 9.0:1 on turbo engines producing big numbers. My built RB25 run 8.5:1 and i think it's pretty responsive 8.8 isn't that far behind it. Its a DE head and when the engine was originally built some 5 years ago, the selection of piston that exist today weren't available. Thanks for the suggestions, any others? Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/#findComment-4020519 Share on other sites More sharing options...
R31Nismoid Posted July 17, 2008 Share Posted July 17, 2008 Hang on, what do you mean not sure of the boost via gauge? Didnt you have it connected to the dyno? Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/#findComment-4020524 Share on other sites More sharing options...
VB- Posted July 17, 2008 Share Posted July 17, 2008 where are you taking the reading from also? make sure its after the cooler, try and make sure your getting 17psi in the plenum. A:F ratio is consistent and safe? Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/#findComment-4020555 Share on other sites More sharing options...
Simonster Posted July 17, 2008 Author Share Posted July 17, 2008 (edited) I meant that he wasn't confident that the car was actually getting 17psi even though that's what it was saying on the SM4 software. It doesn't run any boost controller on the wastegate, just the spring and its a 14psi jobbie. The map sensor is located in the plenum yes. Matt Spry is the tuner, so yes the AFR's are fine Edited July 17, 2008 by Simonster Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/#findComment-4020659 Share on other sites More sharing options...
R31Nismoid Posted July 18, 2008 Share Posted July 18, 2008 No boost controller, off the gate... 14psi spring How on earth is it giving a reading of 17psi then? It'll be running 14psi, or a bit less Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/#findComment-4022059 Share on other sites More sharing options...
Simonster Posted July 18, 2008 Author Share Posted July 18, 2008 No boost controller, off the gate... 14psi springHow on earth is it giving a reading of 17psi then? It'll be running 14psi, or a bit less good question hence 2 boost gauges! We dont' think its really running 17psi...maybe the map sensor in the SM4 is faulty? Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/#findComment-4022623 Share on other sites More sharing options...
Cubes Posted July 18, 2008 Share Posted July 18, 2008 Check the boost its running. A mate with a 1bar actuator went from ~1bar down to 12psi when cams were fitted. He made basically the same power but at a lower boost. Whats the stock gauge saying? Over +7 and its running more than 1bar. I've just dropped in a set of 265 9mm lift cams and boost does not crack 15psi (going by the stock gauge it appears to be around 13psi) I have yet to check what boost it is running as its in for a tune next week but z32 afm volts are up from 4.78v to 4.93v and it definitely clears its throat at 5k where I jump off it in fear of det and lean afr's. Simon I presume?? what are the cam centerlines. Mine are fairly sedate so it idles without a lope (110lca inlet 115lca exhaust 112.5lsa) Push in 5degree's advance and it lopes sounds awesome but is an instant defect, picks up mid range, drops top end 'slightly' and kills economy. I've found at the std LCA's its returning the same economy as it did with the std cams. Throw a dyno graph up. Would like to see the curve as another I know of on the same dyno with 282duration cams gt45 etc is doing the a similar thing looks like its making good power then just falls over and goes flat up top. Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/#findComment-4022742 Share on other sites More sharing options...
Simonster Posted July 18, 2008 Author Share Posted July 18, 2008 Thanks for the replies, and yes its Simon...pretty imaginative eh! The boost gauge he has reads around 12psi when it's apparently supposed to be 17 according to the SM4. I've given him another boost gauge to use as a comparison. I"m also going to check what boost the computer is supposed to be seeing with my laptop tomorrow while he drives. I think they would in 4 degrees of advance on inlet only, power was going in the right direction. Ex is still set to 0. You've got me Cubes, what do you mean by cam centrelines? this engine has a great lumpy idle With the standard cams it made around 320 with an indicated 19 psi, it's still a similar figure but now indicating an alleged 17psi A dyno graph was the first thing i asked for as well, he has one but only a power curve with boost, i wa more interseted in the torque curve- i'll get him to post it up. Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/#findComment-4022939 Share on other sites More sharing options...
Cubes Posted July 18, 2008 Share Posted July 18, 2008 Ignore the other boost gauge hook it up to the dyno. A lot of the jap rb25 cams run with a 115 inlet and 115 exhaust when using vct. Vct then drops the inlet to 111 over 5000rpm which reduces overlap and increases top end. Without VCT then tend to start off with 110/115. The exhaust is fairly good around the 115-118 mark depending on setup. Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/#findComment-4022957 Share on other sites More sharing options...
Simonster Posted July 19, 2008 Author Share Posted July 19, 2008 Ignore the other boost gauge hook it up to the dyno. A lot of the jap rb25 cams run with a 115 inlet and 115 exhaust when using vct. Vct then drops the inlet to 111 over 5000rpm which reduces overlap and increases top end. Without VCT then tend to start off with 110/115. The exhaust is fairly good around the 115-118 mark depending on setup. Its not a VCT head. Thanks, we'll check overlap Link to comment https://www.sau.com.au/forums/topic/228442-rb2530-trouble-shooting/#findComment-4023448 Share on other sites More sharing options...
