I noticed the pic on the website looks different,
Is it still the below design that was agreed on :ermm:
Yes, that was just a quick picture of an S15 shroud.
The picture has now been updated :D
  • Replies 124
Here is the link to pay for the exhaust shroud. We have put it up on our site so that it's easier to track everybody's payment and personal information. Bank deposit is preferred as the shipping calculator will not take into account the advertised shipping price of $16.50. Sorry if this confuses anyone.
Link: http://psiparts.com.au/front.asp?pid=8&amp...ID=R33S-EXHS-CF
If you have any questions, feel free to let me know by PM or email.
Ok so the total amount is $79 + 16.50 = $95.50??
Could you please post bank details? And what format do you want the direct deposit payment reference in?
i would lilke to see a carbon front lip for series 2 front bars. with air diverters on the side.
Yes!! Finally some one else that wants one! I've been looking for months for one and the only way is going to be custom made with a huge cost involved. I dont know why no one makes these, even a universal one for a R33.
Fellas if you can make the order through our website with your personal details it makes it a lot easier to track payments (please use your real name as the description) and avoid any dramas with wrong shipping addresses.
Not 100% sure that this is going to fit my bar, so you can have mine if it doesnt.... Probably could sell it for millions elsewhere, but I'm a nice guy so i'll give it to you for a good price if it doesnt fit ;)
The following information has been sent to you via email for future reference
so you can track the progress of your order and view/print your Tax Invoice
Order Number: 634060528
Password: ********
Date/Time: 2008-08-08 16:15:58
My accountant Mrs Prim Ordial will be sorting out payment for me :( *spanks ass*
Plz don't sue me for sexual harrasment again ;)
hey guys dale sent me a proto and it seems to fit fairly well but will need a small modification I will post pics tonight for you all to see but this will be rectified. And it does fit ser2 :D, great quality and awsome strength!
Guest
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
    • Given that you have seen the dash indicator work briefly, then it would seem like you have a simple wiring problem. What happens when you simply jumper the wires on the "steering wheel switch"?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
    • Maybe I should have written that a bit better lol. I did come 8th last in English at school during the HSC, ironically spent 2 decades reading/writing specifications and contracts in IT 😂
