as above, i have bought 6.5" splits, believing that they were the same size as the factory front speakers.
i have just pulled off the door trim and the woofer cone is just too big to fit into the black speaker holder thing stuck to the door trim.
what to do? :S i splashed $400 on focal splits so buying newbies is NOT an option..
cheers guys
Ric
https://www.sau.com.au/forums/topic/228543-65-splits-into-r33-doors/
Too big as in too deep? The magnet is hitting the door?
Mine were like that (MBQuarts, not cheap either) so some spacers were made up... You're going to have to make some spacers no matter if it's depth or not cause it's not fitting as standard...
not too deep, the cone diameter wouldn't fit in the factory spacer. so all the people on here who have said that the car came stock with 6.5" splits were high?
and the so-called 'expert' where i bought the speakers telling me they will fit no dramas.. grrr..
anyway thanks for your help buddy, at least i know theres a way of making them fit.
Ric
i just put a set of 6.5' focal splits in the front doors in my r33 s2 96 and they go very hard and sound great, i put a set of 6.5' twoway alpine R in the back side panel too, and a set right at the back too. 6x 6.5" speakers = 600watts rms just with speakers
back panel pics, i was bored so i thought i would give it ago
check out the 'installing speakers into skyline doors tutorial' at the top of the car audio and security page. Its pretty much what i did except i made the mdf spacers longer (exactly the same shape as the factory ones) so i could put the plastic plate on (as this is what blocks off the trays in the door trim). Hope that made sense
done the same thing with my panels dont have pics but looks great and different.
im assuming it wont fit into the black moulded peice in the door. just trim it mate and drill new holes its what i did and they fit fine :D
yeah ended up getting out the angle grinder and shaving the sides a bit... just got it to fit. pain in the ass though!
btw focal speakers KICK ASS!! no sound deadening and still pumps fair hard..
When you put your tweeters in don't put them in that little triangle bit next to the window, do this instead,
just need to mark it out and cut it with some snips or use a hole saw on a drill.
and Skylineboy84's idea kicks ass, I'm doing that someday!
Hey man quick question, what size are ur woofers..6"..or 6.5"...cas my speaker covers dont fit the OE door grilles.
Also how did u mount ur speakers to ur door?
Cheers...good job by the way.
6"s
Someone else pulled out the stock grills to put some crappy speakers in and they did a really hack job, so a had to mark out the alpine grill and snip out the door skin to make it fit without showing the door skin.
The speaker itself is mounted in the factory plastic speaker mount behind the door skin and the speaker grill is on the door skin. So theres a 1" to 2" gap between them.
Edited by -Dukes-
I have got some hertz 6.5inch spilts on the front with stock pods
Just basically had to trim a bit off the sides etc.
They deff fit. Just try and trim a bit off
Heres what i did few years ago: http://www.skylinesaustralia.com/forums/Sp...-H-t103289.html
Edited by siddr20
  • 2 months later...
When we did our Project car we worked out the factory speakers are actually 6-3/4" (oversize) which are 17cm speakers. Pioneer make a direct replacement if you don't want to stuff around with chopping and grinding and re-use the standard black insert and speaker grille.
so if 6-3/4" speakers fit into the factory speaker housing, why did my 6.5" ones not? :rant:
  • 4 years later...
Sorry to bring back an old topic guys but im looking for the perfect size that will fit the front doors of an r33 s2. dont want to cut and grind and all that bs. want a straight swap
from above , 6.5' wont work? what will then?
looking at putting splits in (front speakers + tweeters)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
