see if this thread kicks off??
were are there unmarked cops, marked cops, places yoiu see the cops always sitting waiting to get some1??
were do you see them cruze around all the time looking for p plates??
in my area, taylors lakes and shit, melton tmu patrol keilor mountain hwy.
sometimes speed cameras setup on taylors road just after st'albans gym
and another i can remember, radar gun on western ring road, just befor fitzgerald road exit,always sits in the middle of the freeway..
were are your local revenue raisers camping or patroling??
burke road, eastern freeway overpass.. they hide in a really tucked away driveway the cheeky buggers.. that's where i got done speeding :D
This doesn't actually mean on the freeway, they sit in the two driveways to the left as you get of the freeway and head north/just north of the overpass
Western Ring (Radar Guns):
Motorbikes sit under/just off the rd the two foot bridges between Pascoe Vale Rd tunnel and Sydney Rd generally Greensborough bound
Marked but also seen unmarked cars on the side of the road between Sydney Rd and Cragieburn bypass just infront of pipeworks
On the slopes behind the Edgars rd overpass both directions
Service lane at the end of the onramp from the Cragieburn bypass Airport bound (get you as u come down the hill)
The big island at the Greensborough end of the Ring where you get on, (generally facing towards Watsonia)
At the Greensborough end of the Ring were it becomes 90 and splits in 2 they sit up the dirt rd in the middle
yeah eastern freeway has cops, wouldn't go speeding there too often..
my gf just got flashed on elgar road in box hill the other day, just north of the whitehorse road intersection. hooning in her mazda 3 haha
There is a mounted speed camera there when youre coming from the freeway on elgar down towards burwood hwy, just before you cross over whitehorse rd. Gets a lot of people.
When I used to live in Rowville, the stretch of Wellington Rd between Stud Rd and Napoleon Rd always used to have a lot of cops. Especially the curves between stud rd and taylors lane. Common please for booze busses. And cops often hide in the bushes on the sides of the road.
i lost my licence in that very spot lol
f**ken flamin mongrels there always there
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
