I bought this car while I was over in Japan back in May. I was planning on keeping it and developing it to replace my s13 but I have since decided to buy a house and can’t afford to do the build how I would like.
The engine conversion was done 11/2005 and it has since done 4,000kms. The motor used had 90,000klms on it. The engine had a new timing belt and water pump on 10/2007, I have all the paperwork to back this up.
I have replaced the gearbox, engine and diff oils with Labross (high quality synthetic).
I am looking for $20,000. It can’t be registered, it is strictly track only.
1996 Nissan Silvia s14 series 2
120,000klms
Engine
1JZ VVT-i from a JZX100 Chaser
3” Exhaust system
New HKS pod filter
Greddy Intercoler
Custom stainless piping
Greddy alloy radiator
Thermo radiator fan
A/c still fitted!
Drivetrain
JZA80 Supra 5 speed gearbox
Twin plate HKS clutch
New 2 way diff
Suspension
JIC coilovers (Unknown spring rates)
New ‘MAX’ rear toe, traction and camber rose jointed adjustable arms
Alloy rear subframe collars
Body
Full Vertex body kit with Navan rear spoiler
Wheels & Tyres
17” Panasport G4’s (I think they’re 8.5” + 9.5” wide)
F: Advan Neovas
R: Federal 595 ss
Interior
New Bride fixed back seat
300mm Momo leather steering wheel
New electric stepping gauges with warning (boost, oil + water temp)
For more info please call me on 0438 182 855. It can be viewed by arrangement at our yard in Slacks Creek, Brisbane.
Cheers,
Paul.
Pics: http://www.7tune.com/mini-feature-fusion-s14-nissan-silvia/
https://www.sau.com.au/forums/topic/228547-1996-s14a-1jzvvti-conversion/
  • 4 weeks later...
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
  • 4 weeks later...
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
