Hi All,
I just wanted to let everyone know of my recent positive experience buying an import from a Sydney motor dealer.
It's always a bit of a shark field when buying a used performance car (like a mine field, 'cept with sharks) :P
Anyway, I live in QLD but found a place in Sydney called Nagoya Motors that was advertising around the net. It's owned by a russian family (odd eh) and I dealt with a guy there called Alex. Nagoya imports a variety of jap cars - all models of Skylines, stageas, RX7s, Delicas, Lancers etc, and does the compliance work for a lot of them (including the V35 Skylines).
I bought a V35 (significantly cheaper than they are going for in QLD and with some sick Works rims) that was freshly imported a few months before. Mah V35
After driving it back to QLD and going for roadworthy, they found that one of the rear tyres had a 5mm bald strip around the inside that wouldn't pass RWC. And one front tyre was pretty shagged on the inside too. Obviously bad alignment/camber for some time coz there was plenty on the outside of all tyres.
I called Alex and asked if he would like to contribute some money towards a new set of tyres considering it was going to cost me a lot more than expected to reregister the car in QLD. (Bear in mind that the deal was done 2 weeks prior, and my money was long ago in his account.)
Not only did he immediately transfer $400 to my account, but he also sent me a $500 3yr warranty (one of those 3rd party national warranty things) in the mail so I could try to get a intermittant power window motor fixed with it. I KNEW about the window before I bought the car and wasn't worried about it.
So basically a dealer that I have never dealt with before, who has no reason to think I would buy from him again (given that he is interstate) has gone well and truly beyond what was legally required, with zero hassling from me, in order to make me an extra happy customer, and cut his margin by a further $600 or more in the process.
In my experience that sort of ethical behaviour isn't very common in business at all, and virually unheard of in motor dealers.
So if you are looking to buy an import in the near future, I highly recommend Nagoya Motors - go have a chat to Alex. If he doesn't have what you want in stock he can also order it to your spec.
http://nagoyamotors.com.au/
I'm happy for anyone to contact me to verify this story, given that I haven't been on the board long.
Scott.
https://www.sau.com.au/forums/topic/228554-recommendation-for-nagoya-motors/
Yeh Scott,
It's a very comforting feeling to be able to develop trust between buyer & seller eh?
Thanks for your story... Perhaps others will have good words to say about Nagoya P/L and Alex in particular.
Dealers should realise that being able to keep you happy, means that they'll keep your relatives/future children happy too.
This way, they can establish a long-term relationship > loyalty...
rather than silly salesmen trying to just make a sale to keep up monthly figures!
By the way; if you give him a tip, pay him in AU$ eh... NOT ROUBLES!
Cheers, Terry
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
