my car has all of a sudden started to backfire or pop while decelerating. it normally happens while just cruising on the speed limit or so and when i back off for reasons like traffic or coming up to a corner the car will occasionaly give a lttle pop out the exhaust. its nothing loud like the old key bangers i used to do to scare the shit out of pedestrians in the sigma but i was just wondering why it would just start happenening. i fitted the new turbo and front mount a month or so ago so the only reason i can think of is because its so cold at the moment. i adjusted the blow of valve so that it is at its hardest setting but it is a plumb back anyway.
https://www.sau.com.au/forums/topic/228556-decel-backfire/
Mine does the same thing..more so when its in triptronic mode..mine has a big exhaust and Blow off.From what I know it does this as a result of running rich and the poping is unburnt fuel..it can also be a result of a worn out O2 sensor I believe. I dont think it is a major cause for concern...sounds cool...but..the thought of using more fuel than is nessesary..aint a good one.
https://www.sau.com.au/forums/topic/228556-decel-backfire/#findComment-4020867
All it would be is unburnt fuel going out the exhaust, mine used to do it all the time particularly if I go up it then threw out the anchors straight away.
Gut your cat converter and watch for the flames....and the police. :P
https://www.sau.com.au/forums/topic/228556-decel-backfire/#findComment-4021212
yeah i was thinking i might have a small air / vacume leak somewhere as when i boost it i get a little whistle from somewhere other than the normal boost noise. i already have a decat pipe and i have been told that i pop flames on up changes when it tickles the limiter.
https://www.sau.com.au/forums/topic/228556-decel-backfire/#findComment-4021294
It's just un-burnt fuel, and it shouldn't be an issue. When you back off the accelerator, some of that extra fuel might still go through the engine, and when it reaches the exhaust the high temperatures cause small explosions in the exhaust manifold and dump pipes, etc.
https://www.sau.com.au/forums/topic/228556-decel-backfire/#findComment-4023247
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
