Hi all,
Like many others I had an ABS unit that was leaking and did not want to put another 15+ year old unit on that wasn't leaking yet but was going to, probably 2 minuts after I had paid $400 for it.
Having looked around here on the forums it seemed no one had ever tried to repair one. Since I have a background in brake cylinder resleeving, I had been given many odd things to rebuild and repair because they were either too old or expensive to buy new.
I decided to try to repair mine. What was I going to lose? - I already needed a new one !!!
Anyway, I pulled the thing apart right down to nothing to find the internals all in good condition mainly because they are all made from aluminum and therefore doesn't rust or pit easily. Just the seals had gone hard.
So I tracked down a company that sells EPDM seals (the only material that holds up to brake fluid) and we went about matching them all up (about 36 of them). We found all except one and I started the reassembly.
All went well. Four hours went past and I was refitting the unit to my car, bled the system through and hey presto - Job's a goodin.
The unit has now been back on the car for a few days and all seems to good. Brakes work as new and abs funtion is perfect with no leaks .
Any-one that has some mechanical knowledge and the right tools should be able to do this without too much hassle.
I will keep this updated if any problems arise or if any one wants some help doing there own.
GIVE IT A GO! WHAT DO YOU HAVE TO LOSE? MY UNIT IS NOW AS NEW, NOT SECOND HAND.
https://www.sau.com.au/forums/topic/228596-abs-unit-i-rebuilt-it/
Basic tools ie spanners allen keys etc all the normal stuff if you play with cars , nothing exotic
Seals cost me about $75.00 plus some brake fliud got them from a company called Trans seals
If you pull one side of it apart at a time you will always have a referance to look at if you get confused, just take your time and keep things clean .
Ok for those that want to give it ago the company i got the seals from
Trans seals Pty Ltd www.transeals.com.au
1 Atlas court Welshpool WA 6986
08 9458 5766
You will need
number required
2 O-Ring 1.864 x0.070" EPDM-70
2 O-Ring 0.364 x 0.070" EPDM-70
2 O-Ring 0.489 x 0.070" EPDM-70
2 O-Ring 0.612 x 0.103" EPDM-70
2 O-Ring 0.424 x 0.103" EPDM-70
2 O-Ring 0.426 x 0.070" EPDM-70
3 O-Ring 0.609 x 0.103" EPDM-70
3 O-Ring 0.864 x 0.070" EPDM-70
3 O-Ring 0.143 x 0.103" EPDM-70
15 O-Ring 0.176 x 0.070" EPDM-70
2 O-Ring 0.676 x 0.070" EPDM -70
2 O-Ring 0.987 x 0103" EPDM-70
Some PBR rubber grease Available from Repco or the like
Next time i do one i will take photos and do a how to page , until then I'am happy to answer questions .
  • 1 month later...
  • 5 months later...
Nice work!!
Mines always had a very minor leak & didnt want the risk of a 2nd hand unit.
Did you bleed the entire system again once changed or just the nipples on hte ABS unit?
Glad the seals r in Perth, was expecting them to be over east :D have printed out your list. thanks
Mike
Good work. With one exception, I can give the direct reference number, which is much easier for suppliers to work with.
You mention in the first post that one o-ring could not be found. Do you have the dimensions as there might be something available that will be close enough to do the job ??.
  • 7 months later...
Will be doing this in the near future,just ordered the o-rings,will post pics when done.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
