Yeah hey guys, lately the skyline is getting really hard to start, I can hear the starter motor wind but the engine just won’t start and run. Eventually after 3 or 4 cranks the car will start but yeah, pissing me off a little.
So I took the car to the auto leco and they took and cleaned the spark plugs as well as reduced the gap to .8 then started on the injectors cleaned the crap on the bottom of one before they ran out time. This cost $175 and there is no improvement what so ever! They said they will clean the other 5 injectors but that’s going to cost $500!!
Has anyone else had this problem before i spend heaps more?
Car:
R32 GTS-t Japan Import
https://www.sau.com.au/forums/topic/228607-starting-probs-r32/
just bumping this up for pat, basically, it turns over but doesn't fire. You need to do crank it for a few seconds, stop then do it again the. Touch the acc pedal then try again, and it'll fire. It doesn't have the prob when it's warm ie.itll start first go if you start it up again after you've been for a drive
How many km's does your R32 have on it? I know this is a long shot, but you could be losing compression as the worst scenario case. 500 seems a bit steep mate, you can start looking at buying new injectors at that price. Maybe change the plugs and have a look at the coilpacks. What's your oil pressure like? and level? Just a bit of looking around, hard to know what it could be, but by the sounds of it you must think it is electronic taking it to an auto electrician. Try a local mechanic or a reputable mechanic you can trust (if you have one) I haven't got one yet...
Do you work on your car much?
Maybe start tinkering and gain some general knowledge in how your car goes (sry to sound blunt) can help in the diagnostic stages.
Hope that helps :rofl::)
Sam.
I have this problem. not as bad as yours though. mine starts then stalls. my mechanic my injecters are leaking slightly and he said it will be hard to start when cold. mine is also fine as soon as it starts once, then is fine for the rest of the day. its just first start in the morning is rough.
Good luck with it
Sam.
with regards to the 500 being steep, and being able to buy new injectors for that price, thats exactly what i said. previously it had a misfire under loading, in boost, at about 3-4k, but that was resolved by re-gapping the sparkplugs like pat said. I also suggested it may be coilpacks, but seeing as how the plugs fixed the miss, im leaning towards injectors.
The other day when we went for a cruise, oil pressure seemed a little low, but i dont see how this would affect the start up...
Fuel pump!! Change it and the filter.
nah, it has a pretty new aftermarket pump, but the fuel filter might need a change
So many key board mechanics. Meaning well = $
I own an R32 and a mechanic. You need to describe the problem as a cold start issue to anyone you see about it. My cold start has gotten progressively worse since i had mine imported. It used to roar into life when I first bought it and i've only ever treated with the best oil which I suspect has been most R32's undoing. Now when you start it first thing in the morning it will cough and fart for a few seconds until oil pressure builds up properly through the motor.
So, what you, me and everyone else is dealing with is 16+years of redline abuse causing the lifters to bleed down gradually overnight. When your lifters are down your valves don't open. no air and fuel which results in no bangy bangy. When you are cranking you are effectively waiting for the lifters to refill with oil to bring them back up to operate the valves.
Just an idea anyway. hope that helps.
P.S. if you take it to a mechanic A. make sure it is a good one that knows skylines and B. tell them exactly what happens and when. (You cannot leave out vital information like it is a cold start issue or you are wasting thier time and your money) and C. you will have to leave the car for several days possibly, for them to experience it themselves.
I regards to the oil pressure I happen to know someone with a black S2 R33. His oil pressure is quite low and at idle can stall. The car has something like 90XXX km's or so on it and seems to be in farely good nic. How long since your last oil change? Oil gradually becomes thinner as time goes on as you most probably know, which can result in a gradual decrease in pressure. Get some new oil in there :(
I plan on gapping my plugs to .8mm sometime today, not running extremely high boost, but my idle is a little rough.
The oil change will probably not fix your problems, but it can play a factor in an old engine I think, and will help to rule the whole pressure thing out if your leaning that way. If you have recently changed the oil or it is within 5000km's, then don't bother. I would definately put some money on the fuel filter though. I used to get missing and it seems to emphasise the effect with an old filter (going to change again soon, being a bit tight tho because I just bought a new socket set). From what you have said, the fuel pump. etc. is new, so maybe there is restriction possibly caused by the filter - although not neccessarily, because the problem is cold start related, which can lead to questions relating to the age of the engine and the wear. etc. Do some good researching on the rb's and find out what might be problematic in older engines :rofl: which is all I can say.
Could be time for new coilpacks. Investigate the issue further, not really too sure as to what it might be, maybe try PM'ing some of the more experienced members or search for symptoms on the site. Look at the more specific details which may help you cut the variables down on what could be causing the problem, specific sounds.etc.
Hope you can find the problem and fix it mate.
If you have any clues on bucket seats - check my thread :D ha ha.
Sam.
Edited by Ki_spirit
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
