hey guys was just wondering if anyone would know what the turbo specs are on an r34?
ive heard it is a ballbearing..
if someone could tell me what the housing sizes etc. are would be great
and also if anyone can recommend a big power turbo with good repsonse etc.. was thinking TD-06??
any help would be appreciated..
cheers
https://www.sau.com.au/forums/topic/228616-r34-stock-turbo-specs/
This turbo is wanted to put on a rb25 yup?
yeah the motor is a rb25det neo in a r34..
was looking at some cgc or hpergear turbos? are they any good? maybe even kkr..
if im loking at getting a big turbo what would you recommend upgrading aswell.. fuel pump, injectors etc.
i have a pod, exhaust, front mount, and boost controller..
if anyone can help me would be really good :(
if you have an r34 dont skimp on decent mods.
KKR and hypergear are very lazy turbos and not realy worth it. GCG high flows are a waste of time and only lead to other problems. i know this from personal experience on more than one car
a td-06 would be ideal but you would need the full kit. manifold, wastegate, ect. and its out of your current price range.
best bet would be either a HKS GT-RS (i think) which will bolt onto your standard manifold and dump pipe and still offer some thing up around 270 at the wheels.
or a garret in similar spec to the HKS but id go the HKS myself.
for 2k you could probably get a brand new garret or HKS turbo bolt on type and with the little bit of change buy yourself an apexi SAFC so you have a small amount of tuneability. you wont reach its full potential just yet but you will have the heart of the 250 goal in place. you can then add an ecu and injectors and fuel pump later to and keep stepping the power up as you get the mods.
if thats all the money you have to spend i wouldnt look at anything other than a bolt on option like the HKS or garret as once you get into after market manifolds and stuf the money soon climbs. and ebay is not your friend for turbos.
ok the HKS ones are a bit more but check this link out and talk to slide http://www.skylinesaustralia.com/forums/Bo...Ap-t202237.html
Your going to need,
Injectors
fuel pump
AFM (depending on which ecu)
Computer
clutch (if manual)
and of course the turbo.
my budget is around 2k which is why was looking at KKR could pull out some more for ecu etc but at moment manifold, gate, and turbo around 2k..
I miss understood if your budget is $2,000 for the turbo or for the power goal.
If for the power goal then forget it. I don't believe you will ever get that power with second hand parts.
If it is just for turbo I would stay away from hypergear, KKR and hi flows...
You will need cams, flywheel and need to be ringing a highflows neck for prob not even that power.
I believe if it is just for turbo you would be best going for a:
HKS GTRS kit
HKS 2835 Pro S kit
Apexi AX75F82 turbo
Garrett GT3076r
These are a few turbo's to suit that power goal all which you will most likely not be able to get under $2200 bolt on. (though i could be wrong)
In my opinion, save a little more.
Enough for HKS GTRS kit. $2500ish
clutch $1000 (installed)
fuel pump $250
safc tuned $600.
You will have around 230kw on 14-15psi and then when you get other supporting mods you will be more then happy pushing out 270+.
But as said it depends if you can only afford $2000 or if you can afford $6000.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
