Ok so my r33 gtst is boosting at 11.6 psi... .8 bar and i dont have an aftermarket ecu, and i cant make the boost go any lower!! Mods: pod, cold air box, r34smic, 3" dump 3.5" cat back, and a turbosmart dual stage boost controller.
So am i right in thinking the problem lies with the boost controller? I heard they werent that great anyway... and theres no point in me having a dual stage when at the lowest setting its already over what i can run with no aftermarket ecu!
Anyone know where i can get a good cheap manual boost controller? and are they defectable?
Edited by Alex_r33s2gts25t
Have you installed it correctly? You're meant to be able to set exactly the boost you want. Double check you've got it facing the right direction and all the lines are right, oh, and that you've set the knobs correctly.
Turbotech (ebay) make a great & cheap manual controller.
from what i know a less restrictive exhaust can be causing your spike in boost. my mate with a 33gtst had great boost control while stock - after he put on his hks superdrager.. boost control turned to shit.
if ur not planning on going for big power just get a ebc and get the stock computer retuned - something safe 13psi'ish?? will take care of ur problem and will make it safe to run that higher boost for not that much of a cost.
hope this helps.
stef
Hey yeah all the lines are facing the right way and its installed correctly... the knobs are turned as far back as they can go for their lowest setting.... before i did the exhaust (had r34smic, and pod and cover installed) it was boosting at 10psi... i couldnt change it any lower... then with the exhaust now its 11.6psi wtf..
Then again, when the aftermarket boost gauge was telling me 10psi, the factory one was saying about 7-8psi...
i need to get it tuned... then they can test it and tell me wtf its boosting at :)
i need to get it tuned... then they can test it and tell me wtf its boosting at :D
If you're after correct problem diagnosis, shell out a few bucks, get an ECU remap and dynotune at the same time. The following guy is realistically priced and knows his stuff:
http://www.skylinesaustralia.com/forums/Re...no-t210097.html
If you do require a good manual boost controller, a Turbotech is the way to go. Make sure you have an accurate boost gauge before you start modifying boost levels. Don't rely on the factory one!
http://cgi.ebay.com.au/Turbotech-manual-tu...1QQcmdZViewItem
    • Nothing wears "the most". Different cars will always show signs in a different place. 114000 km is either nothing at all (as in, given the calendar age, nearly brand new) or it's completely unbelievable. We stopped believing numbers like that about 15 years ago. Having said that, my car is up around 270000 km and I have put bushes into some places** as many as 10 times in >25 years that I've owned it. ** FUCAs, which are different on an R32 than on a 33, so not likely to be the same issue for you. I have original ball joints all the way around. They are perfectly fine. Same with the spindle bearings in the front. Tie rod ends have all been done at least once though. Pretty much every other bush in the car has been done at least twice. Some of those in the first 100000km after I got it (which was at a genuine 23000!). Some of those bushes are now sphericals, and they are on a <cough> regular maintenance schedule, hence why my FUCAs have been rebuilt so many times. Half of those 10 in the count above would be in the last few years! 'twere I you, I would budget on replacing everything, for fun and prevention. If they really are 30 year old rubber, they will all be unpleasantly aged in one way or another. Whether that's corrosion of shells, or the rubber cracking, or sagging under the load, etc etc.
    • Tighten until it starts to get loose again, then back off 1/4 turn?
    • Do them as you'll find when you remove them they are perished/dried.    Its probably one of the best things to do as makes the car so much more responsive. Do ball joints while there too.
    • Hi All Got an R33, about 114,000km on the clock.  Handles very nice, no signs of issues.    Engine is out and i'm doing an underbody refresh, mainly painting subframe, cosmetics etc. Can't see anything physically giving play, but I'm wondering which bushes are the ones that wear the most, or the first ones that may give problems down the track? For good measure I'm thinking to fit new ones. Thanks
    • This post has OUTER tie rod torque spec - what about INNER tie rod torque spec??? Cannot find this info ANYWHERE.
