Hey everyone,
I know this is been covered in the big thread, and i've been searching for a while now and cant find it so i was hoping someone can help me out.
With a rb30det build which harmonic balancer do you use? For example, if i wanted to use an aftermarket balancer like a ross or ati should i get one to suit my r34 rb25 or are they all pretty much the same.
I'm mainly concerned with all the ps, ac, waterpump etc belts lining up, so which harmonic balancers are interchangable.
All the rb harmonic balancers should bolt onto the rb series engines, but which ones differ for the aux belts? mainly are the rb26s belts different?
:P
https://www.sau.com.au/forums/topic/228624-harmonic-balancers-for-the-rb30det/
cheers for the replies, i was going to buy a ross rb25 balancer but a ross rb26 balancer popped up in the for sale thread at a decent price and i was wondering how different the belts were. For the sake of a couple of hundred saved and possible dramas its probably not worth it, i'll just buy one thats to suit the job
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
