Item:2002 200sx S15 GT Spec wheels and tyres
Age:6 years
Condition:3 are still like new but 1 of them has a scratch about 5cm on it
Price:$500
Contact:PM BEST
Comments:Im selling my brothers S15 GT Spec wheels for him.
They are like new but 1 has a scratch on it
The price is not nego. since 2 of the wheels have new bridgestone rubber on them.
The other 2 are fairly worn down!
Will send at buyer expense
Thanks
https://www.sau.com.au/forums/topic/228627-s15-wheels/
Hi mate,
S15 rims are 16 x 6.5 to my knowledge; same as S14/R33 stockies. Your set are in good condition also. But honestly, (and I'm saying this to help you out with the sale and not being an A-hole), but you've overly priced the rims, EVEN if it's got 2 new tyres. Most sets range anywhere from $90 the set (with worn tyres) to $300 with new tyres. Have a look on nissansilvia.com and hope it will help you with the sale and give you an idea :ermm:
Goodluck =)
https://www.sau.com.au/forums/topic/228627-s15-wheels/#findComment-4052870
Thanks guys for the feedback
But the tyres alone are worth $320 for two!!
They are Bridgestone tyres and werent cheap!
So realistic you are only paying $180 for GT SPEC wheels!
Also they are not normal 200sx wheels they are the shadow chrome ones and there werent too many
https://www.sau.com.au/forums/topic/228627-s15-wheels/#findComment-4072517
  • 3 weeks later...
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
