To ALL JS Auto Imports Customers,
For those of you that know me and my business, know that at JS Auto Imports we offer a product that aims to satisfy all our customer's performance parts needs.
Over the last couple of months we have experienced a number of production problems, which have caused delays and have now been rectified. These problems and the inability to find suitably skilled staff has resulted in a number of delays, which we sincerely apologise for any inconvenience caused.
We also understand that there have been a number of complaints regarding communication with JS Auto Imports. Again we apologise for any inconvenience and are working to rectify this problem. At JS Auto Imports we realise that Customer Service is paramount to providing a quality product and look forward to providing this service to our many loyal customers in the future.
I personally would like to thank all members for there input, from this it has brought things to our attention that need and have been rectifed.
PLEASE NOTE ALL ITEMS HAVE BEEN SENT OUT AND THERE SHOULD BE ARRIVING THIS MORNING OR MONDAY
ALL JOBS CAN BE TRACKED VIA:
http://venus.alliedexpress.com.au/allied/alstart.html#
PLEASE FOLLOW THE LINK AND IMPUT YOUR GIVING CON NOTE NUMBER AND YOUR PERSONAL POSTCODE AND YOU SEE THAT YOUR ITEM HAS BEEN SENT AND WHERE IT IS AT THE MOMENT AND WHEN IT WILL ARRIVE.
LUKE MUSKETT: C1212998
LEIGH WOOLLEY : C12121997
BEZERKLY : C12121982
MARK STOTT: C12121981
MARRE EVENS: C1212999
FOR ALL OTHER MEMBERS WHO HAVE ORDERED: N1 VENTS AND AIR BOX'S
THERE HAVE ALOS BEEN SENT AND ARE IN THE POST.
DAVID GOODWIN: SENT
RYAN PARKER: SENT
NOAH WILKINSON: SENT
Best Regards,
Josh Sarti
JS Auto Imports
https://www.sau.com.au/forums/topic/228634-jsai-public-appology/
  • 2 years later...
BULL.
YOUR PROBLEMS CONTINUE, AND THEY ARE BECOMING OTHER PEOPLE'S PROBLEMS.
IF YOU CAN NOT FOLLOW YOUR WORDS - DON'T MAKE THEM.
AN APOLOGY IS ONLY MADE IF IT WILL NOT OCCUR IN THE FUTURE - EVERYTHING YOU HAVE JUST SAID NOW STANDS AS A LIE JOSH
Oh Dear...
Two and a half years > still going on?
5 things are required to get one's reputation to the top in this field...
1) communication
2) quality product
3) completed on time
4) at the right price
5) packed appropriately and sent
Personally, I had no problems with JSAI - but that was back in January '08
My observations are that botchups centred on #1) & #3), and they occurred time and time again. Correct?
Any more recent feedback?
Very much on the dot!
It's funny, because if you read a few posts Josh put up in 07/08, he complains about warehouses not communicating and delaying - making an oath that his business will tackle all these issues and serve proper customer service. Didn't take him too long to fail.
Really, if your business was going downhill, the last thing you'd want to do is piss more people off.
I've even let him know I want a refund and NO PARTS - no reply to that either. So the Police are now on his arse and his avoiding their calls too. Very trusting
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
