Emanage Ultimate (was only used for about 3 months)
+ universal harness
+ map sensor & map sensor harness (brand new)
+ AFR input harness
cost me $1050 sell for $700
also have innovative LM-1 wideband + RPM converter (was only used for about 3 months)
cost $500 sell $400
or buy both for $1000, everything you need to tune your car yourself
Brisbane
some pictures, why can't I edit my first post??
also have a mdf parcel shelf for 6x9's fits in the back really well
$30
also have gizzmo boost controller, I accidently broke the wires off on the solenoid coil, but I found a place that will sell me a new one for $35 + gst
so will sell for $200 and you get new solenoid or $250 and ill get the solenoid.
Edited by SevenAngryPenguins
I have a Power FC as well $1200, I've had this for less than 12 months and actually used it for only about 4 months, hand controller is in as new condition.
As a note I had this in my car but it stopped working after I installed new injectors, so it was sent to Japan for repair under warranty however it was tested by apexi and they found it working 100% and said problem was with the car.
but yeah if it doesn't work ill definitely refund.
this no editing posts sucks balls.
also since i didn't add its for ecr33
how did the e-manage go on your car?
like did it run well and stuff
and did you need the map sensor & map sensor harness and
AFR input harness to install and run it ?
I had highflow turbo and s15 injectors and it ran really well never had it dynoed but was probably making about 300hp atw, it took a lot of time playing around with the laptop to get it right though since I tuned it myself on the road. I wasn't using the map sensor at the time but was just about to (before I got t-boned) stock afm maxes out really early so it gives you crappy resolution for tuning. For the price its a sweet computer but a lot of stuffing around with the initial setup compared to say a pfc which is virtually plug and play
  • 4 weeks later...
