R33 ECR33 GTS-T Remove Dashboard Gauge Cluster
Translated from: http://www.cyberstork.com/
1. The column of steering wheel basis is removed.
2. The cigar socket is removed, 2 connectors are removed.
3. The ashtray is removed, the screw of the inner part is removed.
4. The shift panel is removed. In case of AT, you step on the foot brake, you insert in LOW turning the key to a ON, lower the emergency brake and pull out.
5. Shift it into park again to use the emergency brake.
6. 3 screws under audio you remove.
7. In order to remove the panel, the door is opened.
8. The front panel is removed, via some mounting clips. Apparently the best method here is to start from the middle and work your way to the edges.
9. On the reverse side is 2 connectors and 1 sensor.
10. On reverse side 1 connectors for mirror
11. Top and bottom 4 these screws are removed.
12. Remove the 3 marked screws, 4 connectors the reverse side.
I didn't take these photos, or write the tute, just translated. Figure someone could use the info quickly. I was researching the cluster myself, and couldnt find any tutes.
Hope it helps
-Al
  • Like 1
https://www.sau.com.au/forums/topic/228667-remove-r33-ecr33-gts-t-cluster/
  • 5 weeks later...
  • 4 weeks later...
  • 1 month later...
Also take note of the plugs in the back of the dash, 2 out of the 3 can be filipped 180 degrees, very poor design and is a pain in the arse when replacing it with a cluster that has the plugs in a different position.
  • 5 months later...
  • 4 months later...
HEY DUDE!!
Ur a legend
Had to high blood pressure for a few days now after a road trip frm Sydney to Melbourne
and my Coil-overs were pretty stiff....n things rattles alot n loosen up the wirings behind my consoles
my Climate controls button malfunction, cigrette lighter fail, cd player malfunctioned and speedometer keep deadening
all n all toook it to a local mech, and quoted me to fix all that $400!! I was LIKE G.T.F.O.O.H.!!
and here I was ponderin away n this Note floated by n I was like why the F*** not give it a go
TA-DA!!! after 1hr pulling n connecting back everythin in place and all works like magic...
$400 is locked up in my wallet, blood pressure to normal....and reliefe! lmao
THANKS BUDDY GOOOD JOB!
-JAi-
  • 4 months later...
hey guys,
need a bit of help with this. my indicators have been wired up the wrong way around (works fine on the outside of the car, but it's backwards in the instrument cluster).. is it difficult to just switch these around when the cluster is pulled out?
if it's too hard i don't want to rip it all out for nothing
I had to pull my cluster out the other day. For my car, an auto R33 GTST there are simply three plugs from the car that connect into the back of the cluster. I can't see any way of swapping the indicators around by just pulling out the cluster. It’s all fixed circuit tracks. Might be something at the plug/further down the wiring.
Edited by S1LV3RTRACKS
yeah, i had a look and came to the same conclusion. my car used to have a nismo dash in it, so they probably re wired some stuff manually. i'll have to whip out the multimeter and go through everything individually.
thanks
  • 3 weeks later...
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
