Hey guys,
I recently installed a r33 gtr fuel pump into my r33 gtst.
The problem is when i pulled my original one out i dont recall it being held into place by anything. When i put the gtr fuel pump in i couldnt find anywhere to clip it, so i put it in the way i thought i pulled the original one out.
It is a louder pump, i was aware of that but it also makes strange noises at lights with half a tank of fuel.
My question is, tomorrow should i clip the bracket onto something (if theres something its suppose to be held onto) or just leave it?
Cheers in advanced.
https://www.sau.com.au/forums/topic/228699-r33-gtr-fuel-pump/
its a bit hard to actually see it, but the whole assembly drops down toward the front end of the tank. the bracket slides into a bit of plastic near the top and the pump hangs down to the bottom. its not the pump that is connected, but the very top of the bracket itself. post a pic of what you took out so we can tell you what happened i dont have pics.
its likely that your pump is just swinning around hanging off the fuel hose. it will be very noisy when it hits the side or if it rises above the fuell level.
Hard up against the inside front wall of the tank, there is a large flat whitish plastic fitting. The metal bracket from the fuel pump slides into this and clips or locks in place.
Have good look and you will see what I mean, sounds like you didn't clip yours in to me.
Easier to do it with 1/4 tank or less.
This might help, its for a 32, but I think they are the same.
http://www.skylinesaustralia.com/forums/R3...ati-t55337.html
I originally attempted this with a full tank of premium, once alot of petrol started pissing out onto the ground i thought HMMMM thats not a nice way to treat golden liquid.
Anyways i dont drive it too much through the week so tried thrashing it around for a bit and ended up doin it with 3/4 tank of fuel which still didnt help plus it was getting dark but i did it anyways.
I know what both of you are saying which helps alot because i had my hand in there and thought i was looking for nothing and making my premium petrol not so premium anymore.
Ill have another crack at it tomorrow now that i have around half a tank or less and will actually be able to see with daylight :D .
Cheers fellas.
Its an easy one to think you got it right and then here the tell tale extra noise of the loose pump and the clunks as you go round a corner etc
I actually had a dud pump and a so called reputable skyline shop changed it, only to miss the bracket. I ended up having to redo it myself later at home and seat the bracket home. So even the 'experts' can get it wrong. But you'll here [or should here] a click as it seats home. A bit of sunshine into the boot helps heaps, park your car so the morning or arvo sun is beaming in.
Yea i did it today, i could actually see where the bracket clips into but the gtr pump wouldnt let it go in so i had to bend it a little.
I could only get it to go in about 1cm, it just wouldnt go anymore so i left it like that. It still made the same noises when sitting at traffic lights so im not sure if its normal or not but as long as it drives then who really cares i guess.
Thanks alot for the help i appreciate it.
aha that may be the fake one... there is one spot which is very similar but it wont go in properly, the actual thing is very close but a bit higher up. I think it may be a case of take it directly up 5 cm or so.
the pump needs to go in a bit crooked, then once its down the bottom you can pull it up and into the bracket, thats why one prong thing is a bit longer than the other on some.
i remember doing thse now and although its great if everything goes well, sometimes you just cant get it in- like all good things in life lol
    • And half of them have been converted to turbos.
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
