guys....
my rear panel shelf vibrates like a b*tch even tho i dont haf subs or an amp.
i have jbl fronts now and the std clarions in the rear.
intending to remove the clarions and put in pioneers...
how do i remove e speakers behind?
how do i remove the seat if indeed thats what i gotta take out first?
thnkas a bunch guyssss:p
https://www.sau.com.au/forums/topic/22873-installing-rear-speakers/
you need to take the seats out, the is 2 bolts betwwen the seats towards the sides of the car, then slide out the parcel tray (flimsy 4mm stuff, then unscrew the stock speakers!! should be able to put 6" straight back in no worries!!!
simple job -- take a while though!!!!
or get some bass with 6X9's on custom MDF parcel tray :D
sounds pretty good with it done like this!!!!
You might find that it's the speakers and not the parcel shelf doing the vibrating - for some reason the rubber surrounds around the speakers deteriorate so quickly in Japan...
When I pulled mine out, there was nothing left of the surrounds, the cones were just free to buzz around as much as they wanted. New speakers - much better!
ive just put in rear speakers...pioneer 2 ways 150w..
rattles even more now and i need amps now cause with powerful jbls in front and pioneers in back, they distort quick...
after alot of yanking and bleeding hands, managed to put in e new speakers and the old clarions were on the verge of extinction and ancientness...
they were made of frikin paper man around the tweeters.
wierd...
odd design. anyone taken em out shud haf seen em.
any idea why such an odd design altho sounding good when new?
stop your parcel shelf rattling by adding sound deadener to them if theyre metal parts, or putting a thicker parcel shelf would help (ie. 18mm mdf) and bolting that down to the metal.
if its the shelf rattling (metal) just add weight to it, if its the parcel shelf on top, u can check bits of foam in between the small wood and metal too.
good luck
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
