  • Replies 43
Hey i was searching for spark plug# to fit gtr32 and i came accross this thread. thats a good video good work I just bought splitfire coils and was going to drop them in today with some new spark plugs only run up to 1bar boost its confussing which ones to get.
NGK bcpr7es-11 change them every time you change the oil
