hello people
just wandering if any one would know how 2 fix this problem ,i had my injectors cleaned and tested.Then put back on the car found out that fuel was just flooding the engine i had a local mahcanic come over 2 check it n he said the injectors was open even without the ignition on.Whats responsible for the injectors opening ? any help would be good thanks :)
https://www.sau.com.au/forums/topic/228735-injectors-staying-open-help/
for one the orings have nothin to do with the engine flooding they just keep the fuel from leaking out of the rail and plenum etc.
its where the solenoid is staying open which lets residual pressure push extra fuel into each cylinder.
normally from experience if its only one injector that played up replace it. but if all have played up either its a electrical issue or the ppl that cleaned ur injector did sumthing terribly wrong lol.
From experience, without the o-rings on, the motor floods.
just curious guys but which o rings r the ones were talking about? the larger one at the top or the smaller one at the bottom of the injector?
Not trying to hijack this thread but the bottom O rings on the side feed injectors have that plastic thing that clips onto the nozzle of the injector which also holds the bottom o ring in place. My question is, can u buy replacement plastic clip things for them and what happens in the situation that you dont put them on?
Kinda vague, just finished work...
Thanks
Chris
If they are staying open even with the power off it sounds like the injector has ceased. If they have been lying around for a while they can cease up. Can also be a result of running them dry. If they were working fine and you toook them out and got them cleaned id go back to the people that cleaned them asking for a new injector.
the injectors havent been used for 3 years n the o rings one of them has a little spilt i showed the guy from the injector cleaning place n he said it was ok ,dam him!Well i'll go try another set of injectors with fuel rail n see how that works out. Thanks guys for the feed back
cuz with side feed they can actually leak down past the orings into the cylinder entry. i double checked i was right i wen out into the shed and ripped one out of a spare rail ive got sittin here. put it all back together now tho so i cant take ne fotos to show u or nethin....
Edited by skylinekid
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
