i have curently jst purchased a 1998 r34 25-gt nissan skyline 4door as a first car, n im having trouble finding a good body kit for it as itz a 4 door, ive considered da uras kits but there not exactly my style, i was wondering if anyone could help me wit bodykits for my car???
n if any1 is able to tell me if u are able to put the rear bars dat are designed for da 2door r34's on my car???
ur help will b much apreciated
https://www.sau.com.au/forums/topic/228740-help-wit-bodykits-for-my-skyline/
Hi,
Josh the owner of www.jsai.com.au manufactures their own bodykits as well as Nismo Z-Tune shape ones. If he can't help then contact Jetspeed, Bodyform or CarMate as a last resort.
Hope that helps.
Terry
I don't know too much about the 4 doors...
but it all depends on your budget...if you've got the money to spend, you can't go past the eastbear kit!
http://www.east-bear.co.jp/shopdetail/003006000011/
Im interested in this aswell, and have been researching for well over a year.
Front bar: No probs, same as a coupe (not GTR though, you need gtr fenders, bonnet and bonnet hinges to fit gtr style bumpers)
Side skirts: Couple of options, east bear, crossfactors and uras do side skirts for the 4door, and the wheel base is the same as the coupe so maybe you can mod coupe skirt to fit, not sure...
Rear bar: Same brands as side skirts, maybe modifications will allow you to fit coupe parts, again not sure...
Edited by Kranker
  • 1 month later...
thnx guys for all da help itz realli appreciated
but like kranker ive had a shitload of trouble gettin a gud kit for my car
ill hav alook at da custom jointz but considerin seellin it n settlin for an r33 wit da way things r goin
but thnx agen for all u guyz help
sorry ill spell properly for you guys okay lol
yehh i been considering the east bear kit man but i been quoted 6,600 for the full kit
i was wonderin if use new of any places dat make custom kits for cars because ive seen a mad gtr conversion on a 4door skyline and i wouldnt mind replecating something like it
and if anyone new how much around about a custom mad kit would set me bak for my car???
Im sure if you looked around a bit more the eastbear kit wouldnt be so expensive.
I got quoted about $3500 all up for paint and install as well. However this was off a friend, but nonetheless, the kit itself should cost around $2500 or thereabouts through most places.
Powerplay imports do them, although they might be a bit pricier, and also havent heard good stories about interstate customer communication. however they are a reputable company.
I would recommend the east bear kit as it is one of the few kits around that dont make your 34 look cheap and tacky. :(
do you know of any places that are selling it for cheaper because i rang powerplay imports and they are the ones that quoted me 6,600 i personally thought it was a bit pricey and was considering going custom and getting what i wanted
because im starting to consider selling up and settling for an r33 or something because i never thought id have this much trouble finding a nice kit for a skyline
Try C-Red in W.A, i got my East Bear front bar off Jeff.................
thanks man ill look into it...because i dont have all the cash for it know but im just starting to consider wether its worth keeping the four door or selling up and getting a 2door r34
  • 3 weeks later...
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
