Hey Lads.
With my impending date with the EPA comin next week, im just in need of one more part. I spoke to the geezers at RE customs, they think that If I just change my exhaust from the Cat back I should be sweet with passing Noise and Emissions test. Now With so many brands and Sizes out their Im a Tad confused, Im assuming 3'' will definantly be a winner with noise. but what Make and Model should I get and How much am I looking at forking out.
Cheers.
https://www.sau.com.au/forums/topic/228760-epa-friendly-cat-back-exhaust/
Hey Lads.
Cheers.
hey mate. umm i gpt EPAd before on my N/A 34, and since i had a sports exhaust on which was fairly loud and didnt have a stock one i had one made up (to pass epa) from the cat back. which is a stockish one for about $100 if you wanted to borrow it to pass the test you could. thats only if you wanted to put your old one back on after.
otherwise to get one made up from the cat back you'll be quoted most probably about $500. pretty much most sports exhausts i found out are 'illegal' cause of the noise decibal level as our car can only have a 90 decibal limit. i passed mine with my stock made up one got 84 decibals.. lol
heres a pic attachment of the stock system if you want to wish to borrow for EPA.
Just remember they note down the size of the exhaust you go to the test with.
So later on, if you get defected again and again for a noisy one, and then keep rocking up with a smaller one... you'll be in a spot of bother with fines and what not.
Just something to remember. Once is ok, i wouldnt try it 3-4 times.
This is very true! they also count how many mufflers/cats you have and make a sketch of what your exhaust system looks like!
so if you get caught a few times either get a 3" system made to comply with the allowed noise levels or pay the $30 to get new number plates lol
^ this i did not know, cheers for the info Ash/Ruffels
i have a HKS Super Dragger catback (modified from an R33) that is as quiet as anything.... at track days and what not, where the cars are idling, get numerous people asking if my car is even on.
The rest of the system is full 3" stainless, split dump/front pipe, 3" hi flow cat. So it is possible to have a 3" system, with a jap aftermarket catback that is legal.
I don't know what db my exhaust is, but not one cop has even bothered to check it when i've been pulled over. But it's f*cking huge exhaust though, 5" tip i think and the main part obviously bigger again, might have something to do with it, i dunno. Shelter for the homeless exhaust i call it :)
what will they do to you if they know you keep changing your exhaust? like u just put a small one on to pass, then put 3" back on, and keep doing that, if they know you are, what will they do to you?
umm im not 100% sure but im pretty sure you keep getting bigger f**k off fines, i read on the sheet something like up to 6,000 not sure though might have to confirm with someone else.
I don't know what db my exhaust is, but not one cop has even bothered to check it when i've been pulled over. But it's f*cking huge exhaust though, 5" tip i think and the main part obviously bigger again, might have something to do with it, i dunno. Shelter for the homeless exhaust i call it :D
Sounds the same as what I've got on the GTR, the exhaust varies from 2.75 inch to closer to 3.25 inch on the outside so I'm pretty sure its a 3inch, HKS Super Dragger muffler (with massive tip, JASMA approved), and large mid-muffler.
Extremely quiet on idle but loud at high revs, so unless you drive around the street at 5K RPM your fine :)
Unfortunately there not made anymore, but there's plenty of other choices out there.
Daldar exhausts can install a Redback Sports catback/pipe system for ~$350 which is designed to sit just under the EPA Level Although its not an asian brand its a good option if you wanna stay safe.
I plan to have one installed in a few weeks with just a really loud rear muffler on and if i ever get EPA's just have them switch out the muffler for the redback recommended one and i know im safe.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
