Hey all. Does anyone know with the new laws what is going on with p-platers and the demerits?
I was told (by a police officer) that if you lose your license on you p-plates you have to start all the way back at the start, as in do everything again, even your log book. Is this right? As Ive been also told that all you have to do is the theory test and hazard test again.
So whats the deal? Also something about a gradual demerit system?
https://www.sau.com.au/forums/topic/228761-p-plate-laws-and-recent-crash/
  • Replies 209
Yep, if your one ur p plates, and u use all ur points.. you have to start again from the start... they pretty much cancel it.
If your not on ur P plates, it simply gets suspended... meaning once you reach the date, you can jump back in your car and start driving again without having to do anything.
It's always been the case that if you get a suspension while on your P's your license gets cancelled. I am from the pre-logbook era and I lost my license the first time, 3 weeks before I was sposed to come off my P's. Had to resit my L's and practical driving tests.
So say you got done doing say for example 100 in a 60 zone, but they didn't actually get the speed due to the fact there was no radar. So would it just go to court I guess and then what would happen? If found guilty? found not guilty? What would you think the decision would be and the punishment if any?
It wasnt me that go caught speeding, someone i know. When asked what evidence there was she said that it would be her visual observation and her notes that she took down. Then he got the summons in the mail saying he was doing 100kph in a 60 going onto 70 zone.
a month or so ago I got done doing in excess of 140 in a 100 zone. me and 6 others actually, all at the same time. and same case as yours. estimated according to the cops speedo and no radar gun.
I called a few of my cop friends to see if what they did was legal. Apparantly they are allowed to. the patrol car speedo does get calibrated every so often (how often..who knows). Both my cop friends said there it's very possible of winning the court battle in these cases, but never guaranteed.. unless of course there was only one police officer in the car and present there..then its 99%. It was my first infringement with nearly 2 years of driving so we all paid the fine ($700 and 5 demerits). 2 of my friends lost their license from it. One was a p plater so I could ask him the next time i see him about what's going on with his.
The reason I paid mine as I said it was my first fine ever and court+lawyer fees would equate to around $700. If you want to take it to court you have to write a letter requesting the matter be disputed in court. (this is for the fine). If not you will have 28 days to pay the fine and thats also the timeframe to send that letter in. I'd dispute it in court if I was losing my license over it.
Sean do you mean if you lose more than 4 points.. or have 4 points remaining? LOSING 4 in total is very harsh.. and isn't good for me.. :)
Edited by Magic
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
