i've prob got 7-8cm clearance up front :glare: you get use to it...
This is not a legal issue in Vic... it's the BODY of the car (including exhaust) which can't be lower than 100mm... side skirts/body kit can be lower...
Sorry, but thats a complete load of crap. In Victoria it is a 100mm from the lowest point of the car. Exhaust, bodykit, whatever. Whatever is closest to the ground!
that's what i thought originally...
hmmm.... will have to double check clearance of front bumper again... i did fiddle with the reo bar the other day, was drooping a little, may have picked up a 1cm :glare:
i'm going to have to watch that then...
don't get the front bar unless you are prepared to get the matching side skirt and rear bar and a set of wheels to match. There's nothing more disgusting than an ultra aggressive front bar and stock everything else or mismatching kits. If you want a veilside kit then stick with the theme, if you want a Do Luck kit, then stick with that.
Go for it.. but make it tasteful and get it fitted and painted well. Remember it will be near impossible to get it painted exactly the same as your (probably 10 year old) paint. Look closely at that red one on the first page for what I mean.
You'll get used to driving with it, and having just spent near $1k on it, you wont forget!
Attraction from hoons, police - you're already in a Skyline, so wont make much difference. Will all depend on how and where you choose to drive!
  • 1 month later...
my front bar is low as.. and yes you do gotta watch where you go.. ramps and stuff.. takes practice to learn.. and go at angles till you learn the point to go on.. but everywhere i go i will reverse into spots when possible..
Not worth it, don't bother, I promise you for a car that you probably just drive to work every day it'll give you the shits. It won't change the look a lot probably look more derelict. And it's an r33 so seriously anything you put on has probably been done many, many times before and won't stand out.
My car came with the standard plastic type M bar and the car is slightly lowered and it still manages to scape on things and I'm careful. If you get a big stupid fiberglass front bar it'll crack and look poxy. If you do do it make sure you keep the original front bar.
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
