I haven't seen an Australian MSTS for E85 or any ethanol blend yet but found a link to what looks like US standards . You can't guarantee that ours are (or will be the same) because what Manildra Group supply and United use for ULP could be different .
Anyhow and interesting read with some handy info on what to do if you sit in this stuff or overdo your BBQ with it ...
http://www.e85fuel.com/pdf/storing-handling-e85.pdf
I would very much like to know more about the strainer device that Gary (SK) mentioned , I think it was in relation to what Methanol racers used to try to keep the water content to an absolute minimum .
Cheers A .
PS RB25's comp cover on a GT3076R won't cut it .
your right the fuel is masking a problem, heat, the gt3076 i have is bastard with a std 25 comp cover, i presume thats why it hits the wall, just cant flow anymore! and is it inflated with 4-5 psi pushed in it!
Well you dont have a GT30. Please dont call it that :D
Its a hybrid.
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
