Half way mark of the season already. Im currently 4th in Targa B, with a 3rd and 2 5th placings. Had some troubles but hopefully they are over and I will be back at the front of the field somewhere. My car will be sporting a new look, lets just say the green is gone. Pity actually, since i made myself a t-shirt!! Ill be wearing it anyway until i make another.
All the usual classes will be racing
HQ
IP/SS
Historic
Targa
Vee's
Regularity (maybe)
Racing usually starts at 11am, practice from 9am. Entry??? $10 i think
Hopefully the weather will be fine. I dont have room to bring all my wheels and tyres this time.
C Ya there!!!Visit My Website
HQ
IP/SS
Historic
Targa
Vee's
Regularity (maybe)
Well i didnt have the meeting I was hoping to have. Still not enough grunt for Symmons. couldnt crack the 63's. Doesnt help when you knock the boost control onto the lowest setting either which I did in Race 1. Then in Race 3 a small vacum hose cracked and came off. And to top it off in Race 4 the power steering belt broke. I drove the last race without it just to finish and get points.
So now its back to Baskerville on Sept 27/28th for the HQ nationals and also the 20th year of HQ's. We should go better there.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
    • Running rich in conditions where it shouldn't probably won't do great things for catalytic converter lifespan. I would fix that sooner than later.
