hi all,
i've got an r32 gtst that i want to put an intercooler on
i've researched it a bit and have decided it will be one of two
- blitz lm (return flow style)
- trust/greddy type ls
my question is, will cutting the hole under the battery tray, as required for the greddy cooler be a defect
is it worth spending the extra money on the return flow style
also, i understand i would have to cut the reo to fit any fmic (is there a way around this?), if i'am defected for other reasons and have to go to regency will they spot the cut reo or can't you see it
cheers
https://www.sau.com.au/forums/topic/228802-intercooler-legalities/
if u cut and go to regency youre screwed.
+1 its just not worth the damn hassle. any good cooler worth its salt will fit into the stock vehicle. cost u more in the longrun if you get defected, and its not worth undermining the integrity of your vehicles structure... at least thats my 2c
Speak to Ryan at ISC or Mark at Exhaust Tech, they can probably fix you up with a nice cooler for your car which wont require cutting
-D
i have a 4inch thick cooler on the front of my 32 and it required very minor cutting to the reo bar, and it still passed regency. if you get a 3inch cooler it will fit no probs, plus cutting the hole under the battery is fine.
if the dudes at regency have a bad day, or his wife gf didnt blow him that night or woteva, and they see anything cut, you will cop the regency big black dildo with no vaseline.... not worth the headfux 4 a streeter. get a GTR...
dave your intercooler is massive!!
i guess the front bar dont fit over that motha!
Iv hade two diffrent bars on the car and both nedded to be cut, its a cheap china GTR DRAG COOLER 600x300x125mm which set me back $500 but im looking at getting a greddy or hks item soon.
so some people have got the greddy ls kit to fit without cutting the reo, or just trimming a little?
has any one been through regency with the hole under battery tray?
yeah my car passed with the cut whole, just make it neat and use some rubber edgeing around the hole so that it wont rub through your cooler pipe, and all will be sweet :D
Pretty much whats been said. My reo bar is cut and i passed regency earlier this week. I got lucky though. Im pretty sure there is a DIY tutorial on SAU
somewhere where someone has installed their cooler without cutting their reo bar at all. Do a search. I'd find it but i cbf XD
cutting a whole into the chassis is where youll be screwed but under the battery tray youll be sweet as. make it neat and youll have know drama's as its not major part of the car.
dont cut the reo bar, if you have to make mods to it just take it off that way you should be fine when it comes to regency time as you can just put it back on insted of looking for another reo bar :D
Edited by Import S13
From memory there should even be a outline for where the hole needs to be cut out on a 32, its where the GTR cooler pipe goes through, so it should be very easy if you use the right size hole saw :D
Edited by DSTROY
as long as you cut the hole under the battery tray is accurate you might not even have to bend any pipes! otherwise you can just use both the standard intercooler holes and run one pipe underneath the cooler
like nos man said, in my 33 i got my cooler piping going thru the standard holes and got a pipe running back underneath my cooler.
I just did my own return piping from the fmic to the stock holes from the smic. No cutting to chassis, reo bar, bodywork, nothing!
I agree that as long as you keep it neat and tidy, you will generally be okay.
:D
My cooler went in without any cutting of the reo, and i have a just jap kit! If you buy a greddy, it will most likely fit without much hassle or custom work.
No cutting Damo, but a bit of bending was required.
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
