Throttle Body Plug That Goes No-where And Oil Catch Can Pipe(s) Questions..?
Hi!
Couple of questions....
1. I've just installed a catch can and couldn't get appropriate 15mm piping, so I used 16mm instead (was imperial sizing but converts to approximately 16mm - you can see the red piping in the JPEG "My Engine Bay" attached to this post...). My qestion is how much pressure are the blow-by gasses under? I have tightened the clamps as much as I think they should go, but is it that pressurised that it will still seep out, as it is the wrong sized piping?
2. In the first JPEG (my engine bay) I have circled a plug (grey one), which is attached to the throttle body, but has nothing going into it? I have attached two other engine bays pics, I found within these forums, with second having both a brown and grey plug connected, and the third only having a grey plug (like mine), but it is connected, whereas mine isn't?? What shoud I do? Is this of concern?
Any advice would be much appreciated!
Thanks!
Pete
Edited by Peter
You have a series 1 GTS-T do you not? That's why you only have one plug for the throttle on/off switch. The Series 2 GTS-T will have 2 plugs so yours is normal.
Edited by teng
Thanks Everyone,
QWK 32 - At the moment I am running a standard ECU - Series 1.
PSI Parts - thanks for that, one less thing to worry about!
MunkybOy - thanks for that also, I suppose then, in manufacture they link up the auto ones, and leave the manual ones blank like yours and mine...
Thanks for all your help!
Pete
    • Curious to why you're not getting Jesse to do the exhaust, seeing that he has just done 2 GTRs with Aes valves.
    • What extra parts are you thinking you'll need to run e85 compared to e30?
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
    • Amazing work Duncan! It is never easy to pick up someone elses project and work all the parts out that are missing
    • Hey Ppl,   I am about to tuned my Infiniti Q60 with E-85 and if you can tell me some location where I can top up my car that would be great.   But my other question, is E-30 available because this tuned requires less mods parts and any info you can offer would be greatly appreciated too!!
