People, I'm wondering what's the likelyhood of being able to find a hub from a different vehicle that is going to fit up to the suspension arms of the S13/14/15. If I have to do some reasonably small mods like using different control arms and what not to get it to fit then I don't mind, only thing I'm worried about is completely ruining my steering/suspension geometry. But I figure people lower their cars insane amounts, use longer control arms and wind in max castor with adjustable arms without too much drama so it shouldn't be too bad.
Reason for this, I want to use some sort of FWD or AWD front hubs so I can convert my cefiro to AWD.
I know that some cefiros came factory fitted AWD, but they utilised the double wishbone suspension from the skyline, whereas the RWD cefiro uses the same suspension as the S13, so I can't just whack the drivetrain in. Buying a factory AWD cefiro is also probably out of the question as I've only ever heard of 1 person owning one and I don't think they'd be a common thing in japan either, if you could find one it'd have to be an 88 model to bring it across.
https://www.sau.com.au/forums/topic/228817-hubs-from-a-different-vehicle/
Yeah, using the front suspension from a skyline is going to involve having to weld the suspension mounts in, which is going to be costly, there is a group in the US that does this conversion to S14's, and they weld in the suspension from the GTR.
Subframe, yep already looked into that.
The gtr upper wishbone/lonk bolts to the body
That is true, but the strut towers in the S13 and RWD-A31 are completely different to the towers in the skyline, it's definitely not a matter of unbolting the upper arm and then drilling holes and bolting it into the S13 (or cefiro).
Even if you did, the strut tower would probably collapse. Alternatively you could cut the towers out of the skyline and then weld them into the cefiro (or S13), but that kind of modification is not reversible and would render the car track only... if it did work.
I managed to find some photos of GTiR uprights, and they look very similar if not identical to the S series uprights. I'm going to go hunting at wreckers to see if I can compare them side by side, at least then I'll have a better idea of whether it's going to work or not.
Not meaning to sound rude, but have you compared your car to a gtr. If you are comcerned about some fairly minor mods to the strut tower, then how do you plan to run the driveshafts through the chassis rails where the gtr is vastly different, or the transfer case, which will require a gtr floorpan/section to be structurally welded in? Im not trying to knock your ideas, but this has been done before, why not just copy what is already a workable solution, there are even detailed photos of the front suspension and underbody on this forum
Edited by Adriano
No I don't have a GTR to compare this to, but I do have a regular R32 in my driveway and I can tell that fitting the double wishbone suspension is not a fairly minor mod to the strut tower.
I am aware there are going to be problems with the transfer case and the chassis rails, but one step at a time...
I am eager to see where this has been done before, I have been looking for research for a while now, this wasn't just some idea I thought up and posted in a couple mins. I haven't been able to find any detailed photos of a conversion like this anywhere, the best I found was the FullRace R14 conversion (GTR engine and gear into the S14) and even then they don't show great detail of the conversion. All you can see is that they have welded in the double wishbone suspension.
I found a thread where someone was considering the conversion to an S15 and uras was saying he was considering putting the double wishbone suspension into the S13, but there were no photos and he said he didn't end up bothering about it because of lack of steering lock...
which is a good point, you can only turn the front wheels soo far if they have driveshafts in them...
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
