i might be trippin.
but i own an r32 gts-t i havent really driven any other manual r32's so its hard for me to really comment but
basically ever since ive owned the car i find it hard to gear change quickly? for example i need to give it a few split seconds
before getting it in the next gear its not that bad but makes it hard to snap gear's niclely on a track if you know what i mean.
other manuals ive driven are easy as so its not me but i think maybe there could be a problem with my trany?
just wanna hear other guys views. are they all like this?
also been told to shorten the shifter with one of those ebay kits you can get? might help?
not sure mechanic says it is a bit hard to gear change in my car so he's changing oil but i think it was changed recently
does any one know much about it? sorry for the long post. cheers
https://www.sau.com.au/forums/topic/228858-cant-get-a-smooth-gear-change/
one other thing i forgot to mention is that it has always been really hard to find reverse in the car you need to pull it right to the side before pulling it back into reverse other wise it wont slot in not sur if that means anything?
Using a short shifter will make it harder as you are loosing mechanical advantage on the lever. It will also wear out your synchros faster. I'd recommend doing the oil change in the gearbox, maybe use something like that redline shockproof?
Just read your signature, if you have that much power and your '20 gearbox is on it's way out, might be time to look into an RB25 box, especially if you intend to be snapping gear changes on track.
Edited by daisu
yeah thats what i thought. i know that the box will go next but you can always hope i suppose.
just still wanna know if it is normal to find it a little hard to find gears or are most 32's with a good box smooth not sure cause i dont have many mate's with 32's?
its yeah id say all of them obviously alot easier going from 3rd to 4th but 1st to second is kinda stubbourn its really not that bad but its not as good as other manuals ive driven
it almost feels the way a van or a 1 tonne ute is
can you get syncros fixed or replaced or is that part of the box? dont know much about transmissions.
reverse is the very hard to engage.
All my gears in my rb20 box are notchy when shifting in. I try to rev-match so its a smoother change :D
Reverse gear sometimes locks me out and have to depress clutch and try again.
If you want to rebuild your rb20 gearbox, it will be around $900 trade-in.
http://www.japanesegearbox.com.au/intro.html Located in Rowville. Last time i was there they had about 10 fully rebuild rb20 boxes on display.
I think they also said an extra $150 for gearbox swap
Give them a shot if you decide on swapping.
Although with 260kw~ might be better to get a 2nd hand rb25 gearbox as they are much stronger.
Although im in the same position and cant decide wether a 2nd hand rb25 gearbox is better than a brand new rb20 box ;)
Hope that helps
Cheers
Patrick
definately not the clutch just changed it and it was the same before..
any more views?
Did you adjust it at all or just threw a new clutch in?
Reverse doesn't have synchros so I can't see how a worn gearbox can result in you not being able to select reverse..
Although im in the same position and cant decide wether a 2nd hand rb25 gearbox is better than a brand new rb20 box :D
Definately worth it. I was sceptical when I first put mine in.. $1500 is a lot to spend for something you aren't sure is going to work but since putting the 25box in, I don't regret it and think it was a much smarter thing to do than put ANOTHER 20 box in again.
my mechanic replaced my clutch and transmission oil. so im guessing he did all the adjustments to it...
considering there was no engine in the car when he replaced it im sure he had a resonable look inside.
any way yeah i think ima start lookin at a 25 box for the power i have my box wont last long...
how much do you think a 25 box is $1500?
for a second hand one? is that not including labour to put it in?
rb25 box sells around $1200-$1800 for a second hand one.
You'll also need some slight customizations to make it work in a r32 too, but i think there are several threads discussing this already :(
I just got myself a 1 tonne clutch put into my 32t and i have the same problems .. usually hard to get into 1st and reverse...but the other gears feel really notchie
mechanic took it back adjusted the clutch and it was fine after that ... you might wanna check your clutch
New clutch, needs adjusting.
Also, my 25box upgrade was about a $2.5k excercise with the full custom tailshaft I had made and purchase of senders, oil, etc. (paid $1500 for a secondhand 25box)
Edited by bubba
  • 7 months later...
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
