Wrecking R32 Gtst W/ Rb25 Conversion
  • Replies 144
Updated again
Bold shows changes from original ad
6x550 side feed blitz injectors in rb25 rail sold
r33 rb25det Power fc inc hand controller sold
r33 S1 RB25DET gearbox with custom 1 piece tail shaft suit r32, modified GTR speedo drive, slave cylinder and modded cross member sold
rb25 det engine loom modded to suit late r32gtst manual. Minor changes will be needed to suit stock afm (4 wires) and o2 sensor(3 wires). currently wired to suit z32AFM $250
GTR front drivers side guard with lip rolled and a small dent above the wheel arch, silver, $200
GTR front drivers side indicator $100
GTSt indicators, pair sold
GTSt front guards with compliance indicators, pair $300
rb25 ignitor $125
rb20/25 CAS $100
And the after market bits
Trust remote mount oil cooler sold
Xtreme XHD 9 puck clutch kit This is now an xhd pressure plate (1040kg or so) with an exedy full face friction plate that is near new. $250
Cusco comp coilovers damper and height adjustable front and rear 8/6 sold
Cusco master cylinder brace suit 32gtst/gtr sold
Whiteline 24mm front sway bar sold
rb20/26/s1rb25 splitfires $400
Trust type R bov sold
Just jap B pillar brace $100
Cusco castor rods bent $75 firm
Maltech braided brake lines ADR compliant $250
Just Jap adjustable front upper control arms sold
Stock front upper arms with nolathane adjustable bushes sold
2 Davies craig 14inch thermos sold
early model hks rb25det cams 256 8.8/264 9.0 inc adjustable exhaust wheel $650.
s1 rb25, no coils, no turbo no injectors. sump has a dent in it where it hit the sway bar but can provide a spare, runs well, good compression $1350
cheers
Dave
And again
r33 S1 RB25DET gearbox with custom 1 piece tail shaft suit r32, modified GTR speedo drive sold
rb25 ignitor $125
rb20/25 CAS $100
rb25 clutch slave $50
rb20/26/s1rb25 splitfires sold
And still no one wants some perfect condition hks cams and an adjustable wheel for cheap!
The bits that are left....
s1 rb25det, no coils, no turbo no injectors. sump has a dent in it where it hit the sway bar but can provide a spare, runs well, good compression $1350
rb25 ignitor $125
rb20/25 CAS $100
plus a heap of random crap thats still got to be pulled out of the shell
 Share
