hi there just wondering will the ignitor suitable for r32gtr? does it come with the loom? and wheres the item locate. cheers
I bent my r32gtst yesterday so i am parting out the salvageable bits of the shell and misc bits and pieces of trims and panels. I also have a few aftermarket bits and pieces and the rb25det and box.
The aftermarket parts listed are all i am offering on that front but obviously i am not listing all of the available stock parts from the wreck so please ask if it's not listed.
If you are interested in something but need more details please pm or post as i am keeping this ad brief due to the number of parts.
I'm negotiable on prices to a certain extent but low ball offers will be ignored.
Almost all parts are still on the car. I would prefer to sell the engine before removing the pfc, coils and looms so that prospective buyers can see it run before removal from the car. After that goes it can be a free for all. I will remove listed parts from sale if i find that they are damaged when i start dismantling. I have not listed any parts that i know are damaged (like radiator, intercooler, z32 afm or power steering pump)
r33 S1 RB25DET long motor with extras inc HKS 256/264 cams and adjustable exhaust cam gear. No turbo, coils or injectors on engine but a rail and 6 stock injectors will be provided separately $2000. Includes all sensors but no looms or alternator/power steering pump/AC compressor.
6x550 side feed blitz injectors in rb25 rail $500
r33 rb25det Power fc inc hand controller $1000
r33 S1 RB25DET gearbox with custom 1 piece tail shaft suit r32, modified GTR speedo drive, slave cylinder and modded cross member $1850
rb25 det engine loom modded to suit late r32gtst manual. Minor changes will be needed to suit stock afm (4 wires) and o2 sensor(3 wires). currently wired to suit z32AFM $250
GTR front drivers side guard with lip rolled and a small dent above the wheel arch, silver, $200
GTR front drivers side indicator $100
GTSt indicators, pair $150
GTSt front guards with compliance indicators, pair $300
rb25 ignitor $125
rb20/25 CAS $100
And the after market bits
Trust remote mount oil cooler $500
Xtreme XHD 9 puck clutch kit $500
Cusco comp coilovers damperand height adjustable front and rear 8/6 $850
Cusco master cylinder brace suit 32gtst/gtr $90
Whiteline 24mm front sway bar $180
rb20/26/s1rb25 splitfires $400
Trust type R bov $200
Just jap B pillar brace $100
Cusco castor rods $150
Maltech braided brake lines ADR compliant $250
Just Jap adjustable front upper control arms $250
Stock front upper arms with nolathane adjustable bushes $150
2 Davies craig 14inch thermos $100 ea. I'll throw in the controller if you buy both.
I can probably pull together the parts for a 32gtst manual conversion (minus box, clutch and flywheel) for $150 or so. Master and slave less than 3 years old.
I have the full interior in reasonable condition except the drivers seat and the carpets a bit rooted.
misc bits and pieces like rb20 and 25 alternators (1 each) rb20 and 25 AC compressors (1 each) rb25 starter motor, various AC lines, full boot trim, etc etc
Most panels rear of the A pillar are ok, though the passenger side door would need repairs to the leading edge.
Thats about all i can think of.
Front brakes, diff, rear arms, rear brakes and rear swaybar are not for sale.
cheers
Dave
  • Replies 144
  • 1 month later...
hey mate
noticed the pic of the semi slicks, if you still have them what size and how much?
thanx dave
from dave
Nah, they are gone.
I do have some r888's in 235/45-17 in similar condition that i'll be getting rid of shortly. 1 or 2 days life left in them at best.
  • 4 weeks later...
The shell and most parts are gone.
Off the top of my head all thats left are the tail lights, a starter motor, a couple of ignitors and an alternator
  • 4 weeks later...
Lower control arm, i have a 33gtst RHS one, plus stock rears
Castor Rod, nope
Swaybar mount, nope
Tie Rod, nope
Castor Rod Brackets Pair, nope
hi...
like t grab this items
just jap b pillar
xtreme clutch
matlech braided brakelines (will this suit HCR32 with ecr33 brakes caliper?)
can use your HKS cams to fit my rb25det sereis 2?
if someone getting the rb head, i would like to get the bottom.
can you ship to port moreby papua new guinea, will pay for the freight.
  • 3 weeks later...
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
