  • Replies 144
am looking for the plastic thingy in the middle that goes around the deck/aircon control etc.
how much ? and where can i pick it up if not how much postage to syd 2165..
ohh and do you still have the intercooler ? :)
Omg! now a million dollar question which I forgot to ask.....is it the same asd the R32 GTR one..if it I will take it..
From all the pics i have seen it is. The reservoir is different but the lid looks to be common between the 2
Hi mate,
I have a panel glued to the back of the surround with gauges mounted and will have to see if i can remove it without damage.
Oil cooler sold
GTSt indicators sold
I am removing the engine tomorrow, i started and videoed the engine today prior to removal so if anyone is interested in the engine i can get a copy of the vid over. The car ran for about a minute before being shut off and idled surprisingly well considering the hole in the intercooler end tank which we found later.
I also carried out a compression test about 5 minutes after taking the video
1) 150psi
2) 152psi
3) 151psi
4) 150psi
5) 150psi
6) 150psi
I was pretty surprised by the results as i have never tested an engine with such consistent compression.
So splitfires and injectors are now available
engine and box are now out of the car.
Passenger side caster rod was found to have a slight bend as seen in the attached photo so price is reduced to $75. It's probably still usable, the threads are fine, ball joints fine so if anyone wants to have a punt, $75 firm or i keep em for bits.
Also pics of some of the other bits i am getting questions about.
gear box cross member was found to be bent. Now separating the box, tailshaft and modded speedo drive
rb25det box $1350
1 piece custom Hardy Spicer tailshaft $350
gtr speedo drive with r33 gear $50
I also have a brand new navara speedo drive i think it still has the original gear on it $50 as well.
rb25det box $1350
Hey mate,
Speedo drive SOLD
Check your PM
Cheers.
i have a stock one but it is far from good. I'm keeping my aftermarket one on the off chance i buy a new car that it suits.
If you need it anyway send me a pm and we can talk price.
now separating the cams, cam gear and engine. I'll remove them from the engine this weekend and reinstall stock cams and cam gear
so early hks rb25det cams 256 8.8/264 9.0 $650. If i find i have a spare stock exhaust wheel i'll chuck in the adjustable one at that price
s1 rb25, no coils, no turbo and a set of stock injectors and a rail. sump has a dent in it where it hit the sway bar but can provide a spare, runs well, good compression $1350
Edited by BHDave
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
