Just a heads up that the enduance racee is currently underway. GTR isn't looking too good, I hear it pitted within the first hour dropping from 5th to 13th then down to 17th. If anyone can understnad the update on GTR-world.net which is in Japanese, please give us some info.
https://www.sau.com.au/forums/topic/228879-tokachi-24-hour-race/
They make them now... At least in prototype form.
The GT-R is still battling away. Been a few more problems. Drive shafts had to be replaced. Then all the hub bolts broke on a rear wheel but they made it back into the pits some how. Both were fairly long pit stops though.
Still out there now clawing its way back up. In 21st place now.
Update anyone?
As Giant says, hub issues likely a human failure. Unlikely that faults like that get through to production.
....... although, now I think about it, bug-eye STi with failing front hub bearings after about 6 hrs racing anyone?
I was at the race for the weekend, just got back. Got to say the GTR was pretty dissappointing. It belted off the line from the rolling start, held 2nd for a lap and then it was all down hill from there, lapping at least 7 seconds a lap slower than the front runners.
It looked great but honestly it sounded like a semi stock exhaust compared to everyone else, overall it was good to see it out there belting around. Thats the 2nd one on that track since late june, one of the HKS customers had theirs out for a track meet a few weeks ago.
I got a few pics and bit of vid that I`ll post up tomorrow as I`m rooted, couple hrs sleep and 5 hr drive home. Pics are nothing flash but got some good carpak action which I`ll post up in the japan page tomorrow as well.
Edited by elrodeo666
Awesome that you were there. I personally wish I had made it out but travelling just for this race is an expensive luxury I couldn't justify :D
Anyways It's a production car in a Super Taikyu race. Not to mention the tires handicap. 7 seconds isn't so bad. Lot's of dramas and unknowns going into the race. Next time they'll know a lot more in terms of what to expect and what to keep an eye on.
The exhaust was basically stock except for cat removal and tips welded on.
I'm surprised the brakes looked so good after they pulled them off the car.
I will explain it all in a sec in detail, gotta run to the shops but in a nutshell the number after the letters denotes the engine capacity. The letters denote the class.
ST = Super Taikyu
EC = Eco Class
IP = International production
4 = 3000cc and over.
Pics not too crash hot, only had my misso`s camera but something anyway...the grey/black GTR was from about 3 weeks at a clubman event we had Tokachi Speedway.
Theres more pics in japan section but of show & shine
post-43319-1216717689_thumb.jpgpost-43319-1216717653_thumb.jpgpost-43319-1216717587_thumb.jpgpost-43319-1216717553_thumb.jpg[
ttachment=172556:IMG_0455.JPG]post-43319-1216717475_thumb.jpgpost-43319-1216717429_thumb.jpgpost-43319-1216717361_thumb.jpg[at
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
