  • Replies 59
if you could get a quote for a s/s version to suit a r34 (would have it in a simular location to where yours is), with the speedflow fittings i would be keen. I believe you that there hasnt been any problems, i'd just rather have peice of mind when i'm booting the shit out of it, knowing that there is no way main oil lines will be leaking/popping off.
Also, could the thermostat be intergrated into the s/s line?
yeah the thermostat can still be used, just means another 4 fittings.
fair enough for wanting peace of mind, it just costs a bit more
im going to have a sus on exact pricing on monday.
how much for just the oil cooler core only ?
pm sent
would this fit a 7mgte / 7mge (from ma70 supra) also interested in speedflow fittings
yeah, it definitely fits the block.
NOW for the few people who are interested in the braided line version with speedflow fittings (blue and red anodised alloy) it will cost another 150-170 on top of each kit price. (not including the thermostat.) That is IF there are a few people who are interested in the kit with the braided line and fittings.
The braided hose itself is actually of a larger diameter also which means less restriction on the system.
So we're looking at around $550-$570 including the braided lines, speedflow fittings and thermostat?
I may be interested. Need to measure if the core will fit in the front of my Stagea somewhere.
I'm interested in an oil cooler with thermostat and speedflow fittings.
+1 definately interested in the whole lot
how many people did you need for the braided version to go ahead?
incorrect. another 4 fittings and 4 adapters are needed for the thermostat.
the kit will be 2nd to none though, with every component being the best you can get.
interested as in deposit interested?
3 deposits of say $80 will get it rolling. 1/2 week turnover.
this whole kit needs to be revised if there is CERTAINTY for the braided version with necessary fittings.
the first quote was for 3.5M of braided hose.
if you measure how much hose you require in TOTAL i can adjust kits to suit.
PLEASE DISCUSS, because the fine details are important.
I'm looking at mounting the oil cooler where the SMIC is. (Will be changed to FMIC of course) So if you could allow for that length. 3.5m should cover it I would think.
if you copied a simular length to what you have in your car, but just in braided line and the provision for the thermostat that should work well. Most people would have it in a simular location to where yours is.
You can definately add me as apart of the group of 3, as soon as 2 other people show interest in the same kit i dont mind putting $80 deposit
:P
:P
I'm sweet for a deposit too.
Hey mate,
Interetsed, but can you please confirm price for full kit, with braided lines long enough to mount on the passenger side of a 32GTR?
Whats the actual size of the core, (Dimensions)
is there any chance of buying the speedflow fittings and ss braided hose by itself?
i'm quite keen as i have a similar setup using the permacool and b&m thermostat with a sertrab core
i'm yet to be install the kit on the car,
and i have always been a little concerned about the rubber hose that is supplied kinking and then restricting the oil flow...
pm me if possible,
thanks,
greg-
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
