This is why vigilante justice is needed. We need to find these f**kers and break their kneecaps and elbows to the point they'll never be able to use them again.
I'll spread the word down Wollongong way as well. Hope everything works out for you guys, you've been nothing but helpful for the whole community.
  • Replies 213
A few more updates guys.
They tried to steal Darron's dirtbike as well from inside, took a stack of Genuine Nissan merchandise including GTR blank keys, R33 GTR centre coin slot covers, our full stock, ie buckets and buckets of stainless hose clamps, they even broke into the Coke machine, stole cans and coins, and ripped off all the charity food on the front counter and the money in the carboard box - it was a kids charity box!
Oh and they also stole around 80 sets of brand new Conrods for most engines as per the first post so please be watchful of anyone selling quantities of rods on unmarked brown cardboard boxes with small white labels stating the engine type on them.
Cheers,
Steve
...they even broke into the Coke machine, stole cans and coins, and ripped off all the charity food on the front counter and the money in the carboard box - it was a kids charity box!
Now that is just pathetic and low!!!
gl with catching the offenders and recovering stolen goods
Thanks Owen.
Cheers,
Steve
sorry to hear steve. as with us all, any info or suspicions will be passed on to you.
this is a huge robbery. seemingly well planned. and yet they stole soft drink and change? it makes no sense. i mean they actually stripped parts from the R35, and then ran to the lolly box to grab coins?
you would have to assume there were alot of them in there for this kind of thing to be going on.
Edited by Munkyb0y
wankers sounds like they got 2 much stuff to get away with. and as for kids charity box thats just realy low.
hope u find the people responsable. i keep my eye out for bits floatin round newi.
good luck in getin up and running again
<br />I am really looking forward to the news of the thieves being caught, good luck.<br />
<br /><br /><br />
^^^ Dragged thru the streets, then burned alive!
:P thats just beyond a joke.... sad day for JJap... great people, great attitude.
As many have said, bounce back bigger and better, don't let these guys take a great business down!!
sounds highly organized to me i doubt they will offload it on ebay, most likely stack it in a container and sell it overseas!
For the most part yes, but apparently the only Brake kits taken were for Falcon and Commodore. I can't see a huge demand for the Falcon kits abroad, same for commodore.
Sorry to hear :D hope you catch these wan*kers
Ive posted a link to this thread on supraforums.com.au
Hopefully someone sees/hears something bout this soon
Good luck
Daniel
    • Not noticeably. Arguably, the catless turbo is going to work harder in a different direction, as it will spool up faster, go to higher speeds more easily. Only if it was tuned in the original condition. If it was a stock tune, using the AFM before and after the cat/dump change, then no, no retune needed. If the car is running on a MAP sensor, then it might well benefit from a retune. It might even run a little dangerously without a retune, but it could quite easily be fine.
    • We had this blend that uses 98RON + 10% Ethanol which brought it to 100RON. It's no longer available anymore unfortunately.
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
