Hi Everyone,
Just need a little technical support, my GTR is running the standard airbox with a K&N filter. My mechanic is telling me to go for some pods and get rid of the factory airbox.
My car already has an HKS drag intercooler and 3.5 inch exhaust from the turbo. I have been told that the only thing letting the car down is its breathing ability and that I should expect a noticable difference.
Any advice would be greatly appreciated
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/
If u do make sure you build some type of cold air intake (see: forced induction area), otherwise you're just going to be sucking in warm air which may give you worse performance.
Some argue pods are a waste of time compared to a good panel filter, but they sound better :(
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491283
Originally posted by Canadian GTR
Leewah
Did any of those GTR's have any mods to their standard airbox,
extra cold air feeds running into their standard box or airflow meters??
No. Because of the way the airbox feeds from the front of the bonnet anyway, it was cold air already feeding to the turbos.
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491337
Leewah,
I guess what I'm trying to find out is if the standard box provides enough air to the turbos given the mods I have, or would an additional air supply be benificial, say for example if I added another cold air feed from the front bar into the standard box.
Or would that be over kill ??
Cheers
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491402
There is no real such thing as overkill when it comes to feeding the turbo cold air. What you need to try to accomplish is giving the turbo as much air as possible as long as the air is cold and directed in a straight line. Turbulant airflow has a very negative effect on the effectivness on a turbo. We found a 4 rwkw loss by simply removing the air pod. We found that the air pod directed airflow in a less turbulant direction so we left it on.
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491453
hehe all i can say is if u slap on that pod go get an engeneers certificate for it or when u get pulled over the nice little men in blue will be putting a nice little yellow sticker on your windscreen, and acting as if there mechanics when there telling you to put back your origanal air filter lol :) good luck mate you got to weigh up the for and against mate but id put one on anyway :D
and if your going to do it do it proply with the right filter dont get some REPCO $5 filter just to save money get quality stuff its enhances the performances and last longer as they say you get what you pay for
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491772
I think I will leave the box standard and try to feed it more air through the front bar.
If anyone had done/tried this on a GTR I would love to know !
Thanks for the help
I know a couple people both in GTRs who run a standard airbox and his best time so far is 11.4@124MPH
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-491942
Thanks everyone,
Thats the great thing about these forums you can chat with people who have been there and done it rather then taking the advise of a mechanic who wants to make more money !!
I'm going to stick with the standard box and get my hands on some cam gears next !!
I will probably need some more help when I get closer to buying them.
Cheers
https://www.sau.com.au/forums/topic/22898-gtr-airbox-advise/#findComment-492974
    • Thanks for the replies guys, I'm new to the world of hybrids. It's definitely a lot cheaper to run than my old m35 stagea that's for sure but yeah well shy of the claimed figures so far, hoping the batteries not poked (although it came with a 3 year warranty for the hybrid battery as well). Wondering if it'll take another tank for the ecu to figure out the higher octane if it's been run on 91 for a bit?
    • welcome to SAU  sounds like you do have a bit of sorting out to do on the car, but it looks nice you can attach pics directly after you've made 10 posts.
    • yeah a coolant pressure test will tell you if you have a leak anywhere as it just pressurises the system. If it drops from where you set it, say 1 bar, you have a leak somewhere
    • Thanks heaps. So basically, bare block, very very similar. And cranks are the same
    • Hey guys, I have dipped my toes into the pool of skylines finally and figured I would get amongst the forums and make an introduction post! My name is Callum, I'm from the north side of Sydney, and I am now 6 months into owning my 1992 R32 GTS-T (already having half of that time off the road in true nissan fashion). It is originally an AH3 car but at some stage of its life it has been resprayed in and out in TH1 with (in the sellers words) extra purple, parked next to an actual TH1 car it is a fair bit lighter in colour. It has also had the original RB20 swapped out for an RB25DET NEO which I presume to be out of a Stagea going off the AWD sump that has been sealed up. I won't go super into detail with mods as I want to create a build thread post soon. Unfortunately the car seems to have had a hard life as many of these have being previously a cheap sub 10k car, and I have barely any history on it so if anyone happens to recognise the car or thinks they may have any history I would LOVE to hear it as I am a bit of a nerd when it comes to car history, the seller had it roughly since 2020 I believe and was from Parramatta area if that helps. Look forward to being a part of the community, I have been to 2 SAUNSW events already (one being in 2022 prior to ownership, and once more a few weekends ago) so you could say I am not brand new to it but can definitely be more involved via the forums! (side note: I am pretty new to forums and struggled to attach pictures of the car, is there an easier method than having to have the pictures on facebook and copying the link from there? would love to know for future reference cheers!)
