I have a very basic knowledge of how atmospheric & plumb back BOV's work, but what I am wondering is how do you go about choosing one that is best suited for your style of driving. i.e. normal street driving, drag, or drift. Is there one type that is best suited for a specific purpose? or is it mearly "that looks good, I like that one" :D Also would the type of BOV depend on the turbo and the amount of horse power it produces?
Edited by Nimmo
https://www.sau.com.au/forums/topic/228980-bovs-which-one/
agreed with the above and it wont get you in any trouble with the law! doesn't really matter on the type of application e.g drifitn/drag etc, if you want a strong reliable bov that has both plumb back or vent to atmosphere, go something like the GBS stealth FX. H
https://www.sau.com.au/forums/topic/228980-bovs-which-one/#findComment-4026294
Im also a rookie so go easy :P....I bought my car with an atmo blow off and 3.5inch exhaust...id like to attract a LIL less attention lol
The blow off is FREAKIN loud...do different brands and models of Atmo bovs make a louder noise? As in can i get a different atmo blowoff so that i can keep that rice pssst that you guys all hate so much...but not as loud? or should i just go back to std?
https://www.sau.com.au/forums/topic/228980-bovs-which-one/#findComment-4026872
if its a Turbosmart one (like mine) you can twist the end of the BOV in to make the noise 'softer', or out to make it 'harder'. When it's on soft, you won't get that noise unless you're on WOT just about, and the other extreme, well you dont get any dosing at all, its a constant pschhh every time you lift your foot off the throttle.
https://www.sau.com.au/forums/topic/228980-bovs-which-one/#findComment-4027050
Hey guys, I don't want to steal this thread but I also don't want to make another topic ...so please forgive my questions nimmo and i'll try to keep it short...
1. How much boost or rwkw can a gtst bov take?
2.I changed my gtst bov to a gtr as I have a bigger turbo... but I want a little more noise (not huge) because I can barely hear the gtr one... anyway to get it abit louder without going atmo?
Thanks!
https://www.sau.com.au/forums/topic/228980-bovs-which-one/#findComment-4028041
No problem WYTSKY I have gotten my answers, thanks guys you have cleared up alot for me. :D
https://www.sau.com.au/forums/topic/228980-bovs-which-one/#findComment-4028194
Im also a rookie so go easy :D ....I bought my car with an atmo blow off and 3.5inch exhaust...id like to attract a LIL less attention lol
Get your mechanic to remove the aftermarket BOV and install the standard one back on, then install an air pod and you will get the nice 'choo' noise and a wicked sucking noise.
Aftermarket BOV do F*** all and just makes noise.
Only time I would use an aftermarket one is on a track, drift car when running very high boost or push the GTR one before the limit.
https://www.sau.com.au/forums/topic/228980-bovs-which-one/#findComment-4028477
Adriano if you are talking to me I already have a pod and apexi power intake... I want the sound as loud as the gtst was on mine... but with a bigger turbo now running about 12-14psi and in my next tune I may be going higher and power levels will be roughly 250rwkw... didn't know if the gtst one would take it so I put on a gtr one...
https://www.sau.com.au/forums/topic/228980-bovs-which-one/#findComment-4029130
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
