hey guys,
its not really a problem but i just want to know why and if i can fix it,
when i put the pedal to the floor say in 2nd you can hear the turbo spooling up and boosting but the car just feels like its holding back,
but when i only put my foot down half throttle the car boosts a lot better,
do i have a leak somewhere? or too much fuel to the engine?
mods are:
RB20DET
greddy fmic
3" front and dump
bosch 040
cheers,
Kyle
https://www.sau.com.au/forums/topic/228982-boost-issues/
i may suggest plugs.
I had the exact same problem in my rb20. Car went better at half throttle rather than full throttle.
At full throttle the car seemed to be holding back and misfiring.
So i say change plugs and gap to .8mm. Clean coil packs with contact cleaner while your at it to.
Cheers Adrian
https://www.sau.com.au/forums/topic/228982-boost-issues/#findComment-4028356
Mate I had the same problem with my 33 a few weeks ago, I had the timing set at RE customes and the car goes much better.
I can only run factory boost though as soon as it goes above 9 psi it retards and looses power.
I was told that if I get a pfc it would be fixed completely.
*edit.. I have the same mods on mine.
https://www.sau.com.au/forums/topic/228982-boost-issues/#findComment-4028544
engine management system like a apexi power fc tuned correctly should fix it
everyone and there pfc its a nearly stock car dumb ass.
yeh check plug gaps, and look for splits in any of the silicon intercooler pipes had a 32 gtr with the a similar problem when he put the boot into it there was a split that would open up and let the boost out but when putting the booting into her slowly it would open up.
and its a real bitch to find to you have the squeez the pipes for it to show.
https://www.sau.com.au/forums/topic/228982-boost-issues/#findComment-4028665
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
